noob briggs and stratton raptor engine question
the5schlueters
Ok I have a briggs and stratton raptor engine. how is the motor meant to be started? I have a pulley off another motor that I set on there and pull it to start it then slide it off after it starts but it don't work all that well. I did not know if there was another way to start it.
here is the motor I have
KartFab
I have seem people start them with ordinary drills, you need some sort of a chuck adapter to get it going.
DeathStarr89
Loose Nut
Davenport, Iowa
Yep, i'd just bolt on a regular Flathead 5HP pull starter. Try to get one of the newest design ones, they are much smoother than the old ones.
It looks like yours already has the correct starter clutch, just pull off that cover plate and slap the new one on. :thumbsup:
tundrabeagle3
Ca
Yea I was going to suggest that but I don't know for sure if it will work. It looks like it would use one of the older pullstarts the newer ones had starter cups and wont work.
Most guys that race karts with Raptor engines like yours use electric racekart starters (like the Burris or minilite brands). The old style 5hp pull starts hold up fine at 3600rpm but tend to have problems at the higher rpm these Raptor engines run at.
the5schlueters
I like the idea of electric start. The way I am doing it now is a pain in the butt. You have to hold the pull start thing on there and pull it at the same time. If it was bolted on it would be much easier but the guy I got it from said that it cant be bolted on.
zbuck
Ft. Wayne, IN
:wai: That guy is correct, you have to change fan shrouds. That fan shroud is designed that way, so that you have to use a hand held starter. the old trick when racing was to run into the starter and jam the engine.
