Torque Converter Question
Chanman1912
I am running a B&S Intek 206 6.5 horsepower motor, it is a custom go kart with a jack-shaft already mounted. The distance from the center line of the jack-shaft to the center line of the crank shaft is roughly 7.5 inches. That isnt much room to run a torque converter with the backing plate and all that. So my question is can I just buy a replacement driver and driven pulley and not use a kit? Just mount the driver pulley on the crank and mount the driven on the jack-shaft. of course finding the right length belt will be a little annoying, but will that work? Or is there something I am missing?
My goal is to get a much better top speed around the 40's (current is 20mph) and not sacrifice any torque. If there is a better method of achieving this, let me know!
P.s. I attached pictures of the setup so you could see what im talking about.
If you buy the parts separately, you will still need to mount them at the required distance that the kit would want them mounted. This is because of the belt length. You won't be able to mount them at any distance and then think that you will get a belt to work. You also have to use the correct belt
Chanman1912
I couldn't just get a belt that is the right length for my new distance? I cant really move my jackshaft, so idk how im going to get it to work with a torque converter.
Nope. Belts are made for the specific distances. You can do without the kit, but you will still have mount them the same distance required by the belts.
Have a look at this site to see what distances you can use.
http://www.gokartsupply.com/tcbelts.htm
If you are not going to change your gearing in any way (ie. sprocket sizes), the TC is not really going to increase your speed much.
Looking at your picture, I'm not sure why you have that jackshaft. It's not being used in a reduction capacity- in fact it's not being used at all?
I think you'd need to get a self-contained ("Kit") CVT like the Comet Tav2, and just get rid of the jackshaft.
I agree about the jackshaft at the moment. I thought it was just acting as an internal sprocket tensioner, because that is all it is doing at the moment. You don't need it.
Chanman1912
I had the jackshaft, because i used it for extra gearing at one point and now it is useless. But i cant get rid of it though because i need it for the torque converter right? dont I need a jackshaft going through the driven pully, how do i get around that?
Chanman1912
A self contained CVT such as the Comet TAV2 does NOT require a separate jackshaft. Go ahead and toss it.
What about the cheap knock off china ones? Do they need a separate jack shaft?
Does that mean that I just connect the sprocket too the shaft that comes on the TC? I feel like it owuldent be that well supported and the torque of the motor will bend the backing plate of the TC
This is a TAV30 self contained TC. No jackshaft is required because it is all on the backplate. You can toss what you have if you get one of these, or any other like it
