Electic drag kart!
Gokartbuilder11
Moore, Oklahoma
I have a school project to make an electric go kart dragster. It actually could've been gas, but electric accelerates faster. Anyways back to the point, I want to build it with as little electrical components as possible. And for a battery charger I will jut be using one of those wall chargers where you have alligator clamps to the battery. We also don't need any speed controllers since its only gonna be used a a drag kart. Anyone got any pics for ideas or any ideas. I know toystory_4wd is good at this stuff and is on a lot so please help. Have to get plans done by next week.
taz2it
It would be best to have a speed controller. However if you are to do it with out one, do it as a step throttle. Meaning a circuit that starts at 12 volt, then steps to 48 volts, then to 36 volts.
I did this with a 24 volt scooter then added a 3rd 12 volt battery and a bypass 'turbo' switch to use after scooter was at full speed on 24 volt. Giving it about a 20% bump. But this get the motor hot and need to add a heat sink to it to help keep it cooler.
fresh101
Pembroke Pines, FL
Use a 24v starter motor and direct one switch to send 24v to the motor, hold on tight as its a quick push and fast. GRAGSTER
Note: if you want faster go for a 18 wheeler truck starter motor.
I remember a barstool racer plans I had that used a starter and a solenoid with a heavy duty switch.
It seemed allright, but it would cook a battery pretty quick. You had to use marine deep cycle batteries
I think this might fry a regular solenoid, but maybe a contactor from a large electric powered machine might do. They can handle high amps current draw.
Sorry- I don't know how I missed this one, but I did.
Actually, electric drive technology really isn't my bag. I hope you've made some progress but here are a few thoughts-
You'll need a very heavy duty motor controller switch, or a good contactor, or something capable of withstanding high-current switching. Attempting to use a "normal" switch will result in welded switch contacts really fast. Might even catch fire.
Also- I'm not a drag racer, but I can tell you this- too much wheelspin won't help your race times. Getting the power to the ground is important. Depending on your setup, you may end up just feeding a ton of power to the motor off the line, and spinning the heck out of 'em.
Don't forget a fuse or circuit breaker. Fire sucks.
fowler
Bullsbrook West Aus
U could run a heavy duty battery isolator then u can do away with a solenoid
http://www.locksafe.com.au/product-detail.php?pId=31
Although this would result in loads of wheel spin
U could wire a set of circuits to achieve set voltages
Then have a set of switchs to accelerate to top speed
I don't know what u would do for a circuit breaker
It's a shame u are not local to me
It's criminal what we thow out
I could give u a large CAT 24v starter motor with bad brushes
At $56 for a set of brushes u get a butt load of torque
So how much power we talking here? Specs of motor, kart weight, batteries ect....
Whats you budget? This aint a cheap hobby.
Even contactors fuse shut sometimes. nice fires there.... seen a few turned into a pile mushy smelly charcoal.
