Help Replace axle or??
Clone
MotorHead
I got this kart for free not sure what kind I think its an Explorer not sure the back axle has been any one know how long it should be and where I can buy another axle any help thanks
Sent from my HTC One S using Tapatalk 2
Well, since it's a dead axle, the replacement only needs to be long enough to hold the wheel & join up to the existing tube & that is something only you can work out...
Clone
MotorHead
Its a dead axle are there any pre fabed axels or can some one put one together for me I'll pay
Clone
MotorHead
I know I could weld on what's broken but I want it to be safe so I was gunna cut off the entire rear axle and put a new one
Forgive me for what may be a silly question, but-
If you contemplated welding on the broken part, and are willing to weld in a whole new assembly, then why would you not fab that new axle assembly yourself instead of outsourcing it?
Clone
MotorHead
I could not really sure where to get metal square tubing and the threaded ends this would be my first welding gig no experience at all just watching you tube vids
Clone
MotorHead
Is this ideal?
You're always best to buy steel tube from a local steel supplier if you have one. Personally, I'd go with a thicker wall. As for the end, drop into a good hardware supplier and buy a Gr5 or 8 bolt of the right size and length.
Would it be a bit easier to convert to a live axle at this point, I know price wise, no, but if if he went with pillow block bearings, it would cut down the amount of welding needed, and 2 is always better than 1.
If it's financially viable, I'd say go for it. Just let's keep in mind that it has the potential to be costly. Requirements may consist of:
*Axle shaft
*Bearings- either pillow blocks or flanges, and some steel for mounting
*May require a new sprocket and/or hub to mount directly to axle
*Wheel hubs and/or new wheels
*New hardware to mount brake to axle, or possibly new brakes.
This is a general list, including SOME possibilities. It is not necessarily a complete list, and some things will depend on your individual application, resources, and ability.
