So if you had this engine, and a go kart frame with no engine, would you use this?
Maybe as a giant messy paperweight.
I have a job, so I would just drop $100 on a brand new harbor freight predator 212 cc engine and forget about the engine. A cracked block is too big of a deal for me (unless I was dealing with a larger small engine(oxymoron?) 13-18 hp range ...
The only real way to fix aluminum is to TIG weld it with alot of cleaning action on the first pass to get the oil out of the crack. If you want it fixed properly, you could have a friend do it that had an AC capable TIG welder, otherwise, paying someone to weld it would probably cost more than buying a new engine.
If i was dirt poor, and that was all I had, absolutely i would use it. That's way better than pushing around a go kart frame. If it had a crack in it, I would just JB weld it up again (if i was poor)
