HELP! Shaft too short??
jamyers
Buffalo Gap, TX
Yup, you need the bronze bushing as a bearing between the belt and pulley.
I'm not understanding what the machine shop did - could you post a pic?
JonathanEngr
Bostic, NC, USA
Okay... so here is what they did. Initially, they were supposed to cut off 1/2 of the "shaft" of the flat plate, and weld it to the piece of the clutch that slides out. This would allow the piece of the clutch to bite onto the shaft. Instead, they cut off 1/2 of the shaft of the flat plate, and then welded the clutch piece to the flat plate! It was horrible... I had 3/8" for a belt, and it was covered with beads of weld. So.... I explained what I wanted again. This time they added in the material (too much) and AGAIN welded it directly to the flat plate. (I can't believe they made these two mistakes when they had a DRAWING of what to do!!!) At the time, I didn't know about the bronze bushing, so instead of correcting them I just took it and left. Attached is a picture of the results.
The good thing is it works at first. Crank the engine, it idles oh so well, but after driving it around it keeps wanting to move while idling. I cut the engine off, and the electric start struggles to turn the engine over since the clutch is still engaged (or because the belt has tightened and is sitting on the shaft without the bronze bushing).
The worst part? Come to find out, the job they did welding it together left it crooked. A buddy of mine noticed the clutch wobbling at idle, so it's just ruined. I ordered a new complete clutch assembly a few minutes ago, and I have someone who is going to weld a one-inch shaft extension with a 5/16" center hole on the end of my current shaft next week. I'll have a new clutch with spacings what they *should* be, all enclosed on the extended shaft. I wish I had thought about this earlier, but with a max torque of 8.5 ft-lbs, it won't take much to hold a shaft extension. A buddy of mine will tig weld the shaft onto the existing shaft, and I'm also attaching a drawing (not complete yet) of the shaft extension. We'll have a 1/8" bevel on both sides, one for ease of guiding parts onto the shaft, and the other 1/8" bevel is to allow an area for welding material to the original shaft.
This has been utterly and completely frustrating!!!!! I've just about paid as much for this drive system as I paid for the entire go kart!
jamyers
Buffalo Gap, TX
OK, now I see...if you didn't need the bronze bushing (and they'd have gotten it welded straight) you'd be in good shape. Sorry it's being a pain, I still can't help but wonder if the small sprocket couldn't be moved to the other side of the driven unit - but I don't have one myself to look at.
Here's a thought - IF you could get the 4-spline hub attached straight, could you cut the straight section of the inner hub completely off (flush with the pulley face like in the pic attached)? Then you'd be able to install a bronze bushing from the inner side, and if the pulley face engages the same key on the crankshaft as everything else, it should work... I think...
JonathanEngr
Bostic, NC, USA
LOL! That's exactly what I thought. I even made a pic similar to yours to post and ask, but didn't do it. 2-1/2" for a standard shaft is so very short... I'm surprised this hasn't come up before. You'd think comet would do just that... key the "flat" plate and put the shaft portion on the 4-spline hub. Lots of bite on both parts, even with limited shaft length.
rmm727
Brookville, PA
I've replaced the keyed shaft for the driven with a longer one I made myself and put the sprocket on the other side of the back plate. (would be under the head on a clone) Had to use a spacer the same thickness as the sprocket when I switched them.
JonathanEngr
Bostic, NC, USA
What a difference a day makes!!!!!
I moved the electric start switch to the front, rewiring everything in the process, and the engine fires up every time. However, it wouldn't shut off. I used the wiring diagram that came from the factory, went outside with my tester and spent two hours trying to figure it out. It was obviously important that it turn off since it sometimes didn't disengage, so I had to get it done. Frustrated, I called the engine manufacturer and the guy told me in 2 seconds what the problem was. The starter switch assembly is grounded to the block via a rivet. If I moved the assembly where it isn't touching metal, it is no longer grounded. I set up a quick ground connection and viola!!!!! Not only does it turn off, but the kill switch now works, too! AWESOME! I rewired it, riveted a ground wire inside of the box and ran it to the frame.
I then jumped on the clutch. It was definitely not disengaging. I had taken the clutch apart and cleaned it as recommended, and have a bottle of Comet lube on the way. So--it was a completely dry assembly. In a last-ditch effort I used a small amount of grease from a tube for lubing fittings. I can clean it off when the other lube comes--if it worked. I put it all back together and WOW!!!!!! The clutch engages and disengages perfectly every time, and there's no roll even without the bushing (the belt is nice and loose now). I even took the belt off after the kids rode for a few hours yesterday, and there's no internal wear on the belt.
Despite all of this, I purchased a new complete clutch assembly (flat plate, clutch, o-ring and so-on) that will be here Monday, and I have a buddy of mine making a shaft extension for me this weekend. So--I'll be back to the way things are MEANT to be run early next week.
My next projects are to install a sound barrier/firewall between the passenger compartment and engine, build a small dashboard for a new keyswitch, choke, horn and light switch, and mount some low wattage lights on top of the roll bar. I also ordered some new, 3-point seat belts that should also be here on Monday (the old ones are a bit rusty). When I'm done, this go kart will be 100% brand new, except for the wheels. I'm going to remove them, remove the tires, use a wire wheel to remove any rust, prime them and paint them with a chrome finish.
It's just so exciting seeing everything work so well!!!!!
Lastly, I truly appreciate all of the replies and assistance I've received from everyone on this forum. Thank you!!!!!
