sno-kart
- Messages
- 120
- Reaction score
- 0
We are trying to pick out the weak links in our drivetrain and we're pretty concerned about putting so much power (our motor is rated at 77hp) through our sprocket hub/axle which has a key/keyway. Our setup is as follows:
Primary clutch drives secondary torque converter via belt. The secondary converter is on a jackshaft (splined) and the other end of the jackshaft has a 10 tooth sprocket (splined) which drives a 38 tooth sprocket which is on our rear axle via a 530 chain (see picture below). The 38 tooth axle sprocket is on an aluminum hub which has a clamp and a keyway (see picture) and our axle is 1.25" solid aluminum with a keyway.
We think that the key/keyway used for the sprocket hub and axle will not stand up to the torque/power of our motor... what do you guys think? We know splines are far stronger and we aren't concerned about the other components which are splined, but this seems to be our weak link.
As for solutions, we've come up with 2:
- Drill a hole (perhaps 1/8") through the sprocket hub and axle all the way through and put a steel pin inside (see picture; the red line shows the location of where the pin would be). Is this a good idea or no? On the one hand, putting a pin through would be like adding two additional "keys" in a sense, but on the other, we are not sure if drilling a hole through our axle would significantly affect its integrity.
- Put keyed collars on either side of the sprocket hub and drill holes through the side of the collars and hub (in 4-6 locations) and put long pins through them. This would in effect extend the mating surface of the sprocket hub to the axle and extend the key/keyway being used which should add some strength. This avoids having to drill through our axle, but we don't know if this would add significant strength.
Any thoughts/solutions/advice are greatly appreciated!
