Engine dies at high speeds
trekklee
Hi I have a yerf dog 32001 with a Tecumseh ohh60 engine and when I'm at high speeds then I can feel that it's slowing down at high revs and it just shuts off at high speeds I just can't feel the engine running as fast as it use to be
trekklee
No one?
KartFab
Check the oil, it could be a low oil shut off sensor kicking in.
Pull your kart on a 5 gallon bucket or something stable so the wheels spin freely.
Get a friend to rev the engine with the gas peddle while you stand at the back and look at the throttle linkage/governor. It could be something as simple as a stretched out throttle cable that you need to adjust. Look and see if anything changes at higher rpms (eg throttle butterfly position) when its slowing down.
Pull the throttle lever with your hand to see if it will rev higher after you try the gas pedal.
Also, look up the manual online for your engine, pay special attention to the rod/spring linkages associated with your throttle and governor. Compare these diagrams to your own throttle and see if anything is out of whack.
fowler
Bullsbrook West Aus
When was the last time you cleaned the carb
It is Likely you either have fuel issues or air issues
Make sure the air filter is clean (ish)
If that is so then clean the carb
Pull the spark plug out
If it is white/brown dry and chalky then the engine is running lean
If it is black then it is running rich
trekklee
My engine doesn't have the oil sensor
You had a couple guys throw a bunch of suggestions at you, and all you bothered to answer about was the low oil sensor.
It's a two way street. If you want to solve these problems, you will need to participate in the process a little better.
trekklee
I know I checking there suggestions right now but some of it is not the problem
trekklee
It's kinda whiteness Ill post a picture see what you say about it
trekklee
Is this good????
