KartFab
Forgive my vocab again, here goes my attempt to explain the situation:
I had what I thought was a seized engine I pulled from a go kart. After a week or two of spraying some penetrating oil into the head, I put a cheater bar to the fly wheel nut to see if anything would move. It would move, but with a lot of effort, and I didn't want to damage it. I pulled the head off, crankcase cover, and pull start cover off. This is the first time I have actually opened a small engine past the crankcase gasket, but I was familiar with its internals. The cylinder and bore were in great shape! It turns out the flywheel was rubbing on the electronic ignition/magneto. I adjusted the (coil?) so it wouldn't rub on the flywheel. The engine turns great, and only has a little carbon build up on the cylinder head and top of the valves. I haven't been able to produce a spark. This could be because a wire is grounded out somewhere (probably from when my son was helping me tear it apart, should be an easy fix) , flywheel to coil spacing etc... but my question is this:
1) Does the flywheel rubbing on the magneto have the potential to damage the magneto/electronic ignition?
2) If the flywheel was off (seems like it only rubs in one spot, but it isn't too far out of round) what are some potential causes of the flywheel being out of round? (assuming it was in round at one point in its life)
The engine was manufactured in 1994, its a briggs and stratton horizontal shaft, flathead ~213 cc. My son is standing right next to me so he wanted these smilies on the post too. A big smiley will be on his face once we put this engine on something.
Since this is kind of a junk/fixxer upper motor, I got to thinking... hey the governor is right here and it just pops out... coool... I wonder if i could put my dremel to the intake/exhaust ports while im in here..... oh yea... nvm back to the flywheel.
my son seems to think its the fun limiter. I forget what its real name is.
You can pull forever and the engine still won't start if you don't flip that switch!
