Desertduler
- Messages
- 1,736
- Reaction score
- 9
This is my Wankel powered kart that I built from scratch it is my own design and is for dry lake bed and dirt road driving I am getting ready to install a different Wankel engine in the kart.
lolHi,The reason for the glowing exhaust is the 270 degrees of exhaust duration that is why the exhaust manifolds and header pipes are made of stainless steel these engines do indeed create alot of heat and I keep the air fuel ratio on the rich side,There was a complete set of apex seals recently on ebay for a 303 every once and a while apex and side seals will show up on ebay I use top quality oil in these engines and keep the dust out of them to keep them alive for now I just put new seals in my KM24 and it should last a long time in a kart the 303 I have currently still has plenty of life left in it.Awesome, i have 2 of these motors, waiting for a machine to put them in. Most likely only have enough parts for 1 motor though, as one will need new bearings and apex seals, and the bore is slightly pitted. I read somewhere that you can machine down apex seals from a mazda to fit the 303 wankels. so thats something to keep in mind if you ever need some.
Have you had any heat issues? these motors were known for running pretty hot in the sleds, glowing manifolds weren't uncommon, i assume jetting up a little would help.
