Electric Recliner Kart
easy 'cliner
NJ
Hi all, I admittedly have no idea what I am doing. I don't expect anyone to know how to build what I am trying to build, but any ideas on any of the issues I bring up is greatly appreciated.
Really want to build a powered, four wheeled chair (the one I have in mind currently is actually not a recliner, wanted to keep the seat tight, light, and small). I have never built anything and have turned some infrequent wrenches on cars-- I want to work on a few fun smaller projects before I start to work on things with plates. Anyway, questions I had were:
1) Chassis:
What is the best way to go about a chassis? Ideally I would like the frame to fit completely under the chair, which isn't large. I'm 5'10, 200 and fit comfortably. It's smaller and low backed, maybe under 60lbs. Is it possible to fit a motor and wheels under this? I'm not opposed to the wheels being visible, but don't just want to have what looks like a chair bolted on a go kart.
2) Motor:
What kind of motor do I need to pull it? I want to do electric so I am less prone to being hassled by cops and so that I can use it indoors. Is there a recommended HP or brand? Again, we're talking my weight plus the chair being 260ish, plus the as of yet unknown weight of the motor and frame, and I want it to do maybe 5-10mph? Again, I don't even know the realm of feasible expectations with this.
3) Controls:
I want it to be set up with no pedals or steering wheel. I was originally considering just picking up a powered wheelchair off Craigslist, but didn't think it would look as natural as I'm trying to make it look. What kind of controllers exist for electric motors? Is there any kind of electric/ power steering setup for go karts? I know people build awfully large remote control vehicles (even quads/ larger karts) and was wondering what kind of setup that entails. Otherwise, how hard would it be to create a system where a lever that you push forward/pull back controls left/right steering? (think controls in a paddle boat).
4) Power Supply
Assuming any of the aforementioned specifications are possible and in my grasp, what are my options for juice? I would want to be able to drive it for at least an hour.
Is this remotely possible, or the completely f*cked imaginings of someone who doesn't have a grasp on engineering?
P.S.—
5) Keep it simple(r):
Is the biggest hindrance to keeping it small but study and not 1 mph, with a decent run time, to make it gas? Because I'll take my chances being hassled if this thing will actually look sharp and be fun to ride, and would compromise the controls as well and make them as unobtrusive to the 'stock' furniture look.
P.P.S.— I haven't mentioned brakes because if it's electric, I don't see it building up enough momentum to really coast, and if it's gas, then I'll just use it in the more rural areas near me— i.e. room to coast to a stop.
DaiSan76
Nixa, MO
To get that kind of speed, you'll probably want a 1000w motor, and you'll want two of them so that you can make your chair pivot.
2 controllers $70 each
http://tncscooters.com/index.php?route=product/product&path=41_76&product_id=190
2 1000 watt motors $100 each
http://tncscooters.com/index.php?route=product/product&path=52_58&product_id=329
4 batteries to get 60 volts $284 each (These will run a trolling motor for 12 hours, you can get one that will run a trolling motor for 4 hours at Walmart for about $105)
http://www.optimabatteries.com/us/e...roup-31-dual-purpose-deep-cycle-and-starting/
easy 'cliner
NJ
Thank you, DaiSan. Now when you say make it pivot, you mean one motor for left side wheels and one for right side? To give it like, tank controls? Also, is it possible to make this thing as simplified as having all the batteries charge off one three prong extension cable?
DaiSan76
Nixa, MO
1) Yes, There is a build running around somewhere that I am trying to find a link for. I'm sure you can do things more efficiently than what I have linked, but I never got past the price of batteries.
2) I'm sure you can, but I don't know how. Maybe a switch to go between the charging circuit and the controller circuit.
This isn't the build I had in mind, but it's pretty similar.
http://www.youtube.com/watch?v=JvO89GneiFQ
easy 'cliner
NJ
Oh man, you're killin me. Maybe I need to swap discretion for blatantly building a chair with tank treads...
FatCat
2 stroke Addict!
Ottawa, IL
Could try to find an old power chair and take the parts off it. They can be very expensive though. Maybe one thats older and needs work. My dads was $8000 new. Would be perfect for perfect for a project like this. I saw one like it for sale for $300. Worked fine but was cosmetically rough. Looked like a big dog got ahold of it. Lol
ML-TOYS
long island, new york
I have all the controlls from a joystick controlled power chair i can shoot some pics if interested.
Very similar to this one.
FatCat
2 stroke Addict!
Ottawa, IL
That's the setup. Joystick in the arm of the chair and off you go. They already have the quite compact. Could put the controls under a chair.
easy 'cliner
NJ
One other question... any suggestions on a frame? I've decided that I will be buying a children's recliner from Walmart. They're fifty bucks and fit me like a cockpit, I don't know how, but it's flawless. Anyway, it's 22" long by 23" wide... what can I get as a chassis for that? Are there any for go karts you know with those dimensions or smaller? Or am I looking at having someone with a welder make a tubular square and throwing sheet metal across?
http://mobile.walmart.com/m/phoenix...ile-Vinyl-Recliner-Black/17167607?type=search
