We're not talking about a 2-stroke or sled engine, though. It's a simple, 4-stroke L-head. The absence or presence of an air filter should not make any tangible difference.
No- I don't have much experience with sled engines like you describe- But can you find any other way to explain the fact that I can (and have) installed and removed the air filters (and housings) on any one of the multitude of small engines I have worked on over many years with ZERO difference in performance?
For clarification to all parties involved, "Back Pressure" would refer to a restriction (in the case of an engine) in the exhaust system. I would NOT consider it an appropriate term to refer to a vacuum restriction, or the aspiration system in our case.
Either way- One thing we agree on- lean. So go ahead and pop that air box on. If it clears you up, then the engine was jetted on the lean side or has a slight fuel restriction. If it doesn't, continue the process.
