Briggs Raptor Gearing
Gokartracer
Hey, i got a briggs raptor on a gokart and im racing it on a 1/4 mile cement oval, i was wondering what to gear it at?
jamyers
Buffalo Gap, TX
Welcome to the site! Got pics of your kart?
Probably best to ask over at a racing site like http://karting.4cycle.com
Not trying to blow you off, but they're likely to have a lot more experience with racing - while there are racers here, most of us just build / ride for fun, not necessarily for competition.
You could try PM'ing Anderkart- one of our resident race gurus. However, I suspect he'd say it depends on many factors, and might only be able to give you a ballpark.
Welcome to the forum!
zbuck
Ft. Wayne, IN
:wai::
good idea Jamyer. Stock/moded Raptor? Do you have practice day/night at the track? If so check with the racers in your class and see what gear they are running (some will tell you and some will not), you also need to check the tire size. In any class that we run, we fiqure the gearing so that the engine will keep pulling all way down the strait.
Your track probably has a tech director/inspector, I'd sugest you start by asking him for gearing suggestions, these guys are usually very helpful to new racers.
You could also try asking some of the other guys that race (and win) in your class, but you'll find they might just BS you because they typically try to keep their setup info a secret.
What gearing are you running now? (post the tooth count of your clutch and axle sprockets)
Do you have a tach? (If so, what RPM are you hitting at the end of the straightaways before you lift for the corners?)
Gokartracer
Now I have a 10 tooth clutch and a 70 tooth sprocket, I want to get 17 driver and a 64 sprocket, thats what i've been seeing on every other forum, I do have a tach and it get up to 6400 Rpms
