predator 420cc engine cheap jackshaft setup
realfast89gt
Kart Krazy!!
cibolo Tx
I figured i would let people know about the bmi jackshaft kit selling right now. It is selling for $28, and comes with the mounting plate with bolt holes exactly the same as the 420cc engine. Also includes bearings and 10" 3/4 jackshaft.
I am currently buying one and thought it was a real good deal. I went to get some metal for the engine mount, but a 12"x8"x1/4" thick piece of metal sells for $30 at lowes!!
:wai:
realfast89gt
Kart Krazy!!
cibolo Tx
Oh, gawd. NEVER buy steel from a big-box store... They do things to you that just ain't natural!
Yes on some of the metal i agree, but after shipping most metal i have needed is about the same cost as lowes and i havent found any metal shops in my area that sell metal.
realfast89gt
Kart Krazy!!
cibolo Tx
I believe drilling 2 holes if you had to wouldnt kill you if that is the case......but the manual i downloaded from harbor freights website for the 420 cc this morning had more pages and showed the bolt pattern the same as the mount.
Now that i think of it i downloaded it from another site, might have been the older model.....either way it will still fit with minor drilling and is a good deal.
rmm727
Brookville, PA
You'd have to drill 3 holes. A big block mounting pattern is longer and wider than the small blocks. Plus, they use larger bolts so you'd still have to enlarge the forth hole.
realfast89gt
Kart Krazy!!
cibolo Tx
Just wanted to give you an update on this jackshaft setup. The 420cc engine bolts up without modifications. There are multiple mounting holes drilled in the mount. The only problem i ran into is the jackshaft is too short for my setup, but $15 for a 14" jackshaft and problem solved. I now have an extra jackshaft for my next project.
