craigs list find
samirar
Hello I'm a newbie and I just got a go cart sunday for $125.00 with a 5hp briggs and stratton engine that was built in the 90s and it sat in a barn for 23 years. Sunday me and my friend went to go and look at the go cart after I talked to the guy about the go cart. Before I went to see the go cart I got a new spark plug and some starting fluid. and we got the guys house and me and my friend looked at the go cart and tested the compression and looked at the oil level and checked the gas tank and it had signs of sitting up a long time. and we took the old spark plug out and sprayed some starting fluid in there and put the new spark plug in and cranked the engine and it fired up for 3 seconds and died. and I bought the go cart. Then when I got home and took apart the carb and cleaned it out and one jet was clogged up and got the tank cleaned out put some new fuel in and drained the oil and put some fresh oil in and cranked it up and run and it needed it some carb adjustment to run right and I put a new chain on since the old one was stiff and frozen. and notice the clutch was shot. so I put a new one on and now the engine runs like a new one and drives a like a new go cart does
samirar
I will get some more pics of it tomorrow
samirar
toystory_4wdCarter Superwheels. I have one. Since mine was purchased as a bare frame, I'm interested to see the factory rearend setup.
I will get some pics of the factory rearend setup tomorrow
Welcome to the forum. You scored on that kart. It always amazes me how hardy engines actually are. They can sit forever, and with just a little bit of maintenance you can get it running
jamyers
Buffalo Gap, TX
GOOD for you - glad to see somebody taking the time/effort to bring an old engine back to life!!!
And WELCOME to the forum!
samirar
today my spark plug fouled out and when I was looking in where the spark plug goes in at there is some carbon build up and carbon in the exhaust port. should I be concerned about that?
jamyers
Buffalo Gap, TX
You might put the rear up on blocks so you can run the engine at high rpm, get a spray-bottle with water in it, and with the engine warmed up and running at high rpm, spritz water into the carb - a spray, not a stream - so it can flash to steam with the combustion and clean the carbon out. Don't shoot a bunch of liquid in there, don't want to hydro-lock the engine and murder it.
If you're not comfortable doing that, drizzle some atf into the carb, it'll do pretty much the same thing, plus make an impressive smokescreen.
cOw
Raleigh, NC
What is this atf that you mentioned?
samirar
I have a question about the carburetor diaphragm. I have a old briggs carburetor that I cleaned and it haves the 4 bolts that holds the bowl on with the diaphragm and I put the newer type on it and it is getting way to much fuel and causing my spark plug to foul out and turn black and the tip. any suggestions?
You have a pulse jet carb. What bowl are you talking about. Have you got a pic or two?
