cheaper FNR gearbox options?
dunebuggydiy
nederland,texas
ive got a mower transaxle and a outboard motor, i may be able to get a new atc 250r cylinder and piston from my cousin, then i still dont have reverse.
dunebuggydiy
nederland,texas
no, i have the 82 they put the reverse in 84 along wiht the radatior. is the 3 wheeler also. but i have all of its parts and all of the atv parts, and all the mower parts, and an outboard motor.
dunebuggydiy
nederland,texas
my other cousin owns a machine shop, and i get free time in there whenever i need, and all of his employees help me. and if i really need it, i could get car parts from my uncles junk yard.:thumbsup:
Well, then maybe there's hope. You need to find a way to isolate and mount the outboard gearbox, and be able to seal it so it will hold lube. You may be best to construct a new box to contain the gears and shift mechanism.
In terms of the big picture, you'll probably need to mount that box AFTER the cvt. That way, it's input shaft is not spinning when you shift.
dunebuggydiy
nederland,texas
the dune buggy is solid, no suspension, so that should be easy, and ill get my cousin to make a box to house the gears and all that, if i get the 3 wheeler cylinder and piston then it will be my motor, and ill have to have 2 shifters.
Bluethunder3320
i like the idea of using the least number of different machines possible. youd have to find a way to get hose fittings on the inlet/outlet but its possible
but also boat motors are very expensive if you had a complete one you might as well sell it and youd probably be able to buy an entire buggy
