cheaper FNR gearbox options?
dunebuggydiy
nederland,texas
would a lower unit from an outboard motor running from a chain on my torque converter to the unit then on the other side a nother chain going to the axle? i know they dont have gears just FNR.
Any other ideas?
jamyers
Buffalo Gap, TX
An out drive unit might work... Keep in mind it'll be a right-angle drive, and shifting will probably be a problem, as they're designed to drop straight into gear with the engine AT IDLE, which means 800rpm max - and our engines typically idle at 1600-1800.
I think it's be a difficult project with dubious results.
Lawn mower transaxle?
dunebuggydiy
nederland,texas
im wanting to use a 4 wheeler rear axle under a thunderkart big thunder with a 200cc tec engine. i have a torque converter and i need to figure out the reverse as im going to use it to offroad and for when i go hunting to get to my stand. im using the 4 wheeler wiring harness. but the engine is shot. and then i have everything from a 82 atc250r (2 years before the watercooled engines and 2 years before reverse) but that engine has a scored cylinder and piston. so im stuck with that if you have any better ideas then please help...
exenos
Project Nut
The outdrive will probably be fine if you get one from a 9.9 or larger because your going to run a clutch before the fnr.
jamyers
Buffalo Gap, TX
Actually, since you've got a TC that'll allow the trans to rest when you shift (at a stop), an outdrive lower housing should be ok, mounting it is going to be interesting...
dunebuggydiy
nederland,texas
it will be interesting itll probably be mounted at 90 degrees and then ill use the atv exaust to keep it from singing my hair because it was a 200cc engine too . the atv i have everything from it.
the atc 250r i have everything but the frame. it is being rewelded.
if yall have any better ideas using those parts then please let me know. im not goung to have any suspension on it so i wont have to worry about movment of the axle and ill just make a mechanical linkage for it to shift
jamyers
Buffalo Gap, TX
i dont think outboard motor transmissions are designed to take much load, they are only turning a prop
Nope, they're made to take way more load than any engine you could fit onto a gokart, lol. Marine drives operate at 60-90% of their rated power nearly all of the time, there's no coasting - and whenever the prop is turning, the water is resisting.
what about using a weedeater or chainsaw motor with cin. clutch mounted the other way with a really low gear ratio.
to another sprocket on the axle
That might work if it is geared extremely low. The hassle of having 2 engines to contend with as well as 2 throttles etc might make things a bit complicated
Blue- Think about that! If that water propeller was in the air, then, no- almost no load. Now, think about some big, honking 100hp engine, connected to that little no-load prop, giving your bad-boy ski boat one heck of a holeshot when you smash the throttle! You dang right it's seeing a substantial load! Sure- there's no mechanical connection between the prop and the water, it's more of a fluid drive system (actually, quite true)- like a hydrostatic transmission, or the torque convertor on your truck. Shock loads are reduced, but still a lot of torque being transmitted.
The MOST efficient solution would be chain, direct. But most efficient is almost never the best solution for any given set of circumstances.
dunebuggydiy
nederland,texas
i cant do that in mud. i wont have any traction, like in my shoes.
and when i hook up the trailer with the off roading lawn mower on it i need to have reverse.
