my 8hp engine
momoe
so i bought this today for $80
its a snow blower engine, 3/4" shaft, 8 hp. i hesitated to buy it but then i saw it mounted on his home made gokart so i was comfortable with it
the seller told me what it was, but he was french so i didnt get him that well lol... what is it lol ? and how old does it look like ?
any idea what those things on the sides are, i see a nut on the left thing (wheel )but the right doesnt have bolts or nuts or anything
underneath the muffler i think the carburetor is there .. i thinnnkkk thre is something there that when u unscrew it drains gas out
anyways a couple of questions, y'all are guna laugh ur a**es off...
the choke switch should be on on, off, or in the middle ?
this black ball,, why do you usually press it before you start ur engine?
i looked at my gas tank, it looks dirty, how do i flush it without getting it to the engine ?
how do i change the oil and find the oil drainage nut ,, if any (toystory 4wd answered but i dont know where exactly on the my engine)
u guys think its a good idea to go to a mechanic to do these stuff for me ?? specially to remove that wheel next to the shaft
enjoy ur cheap laughter lol, thanks
souperman000
Westlake Village, CA
That looks like a 60s era engine.
The choke switch should be "on" for a cold start, and then moved to "off" once the engine warms up. Once the engine is warm, you don't need to use the choke anymore.
The black ball, I am guessing is a primer bulb. Press it a few times (3 - 4) to get the fuel flowing, making it easier to start.
Take the hose off the bottom of the tank, so that just the hole is there. Flush into an appropriate container.
The oil drainage nut should be on the botton. Look for a square screw around the mounting area. If you can find a model number, look it up on the internet. If you can find a manual that should tell you how much oil to put in it. There should be an oil fill tab around the drain plug (usually yellow or orange). Pour the oil in there.
jamyers
Buffalo Gap, TX
Yup, looks like an earlier version of SouperMan's and my engines, only yours has a auxiliary drive (that shaft on the right should rotate half-speed and opposite to the crankshaft on the left).
Oil drain should be a square plug in the center of the bottom edge, way under the muffler and/or gas tank. Should be an oil-fill plug just above and to the drain's side, fill it until oil just runs back out.
To clean the fuel tank, best to unbolt it from the engine, then you can slosh it around easy. If its insides are really funky, put some BB's or even small nuts/bolts in it along with some automatic tranny fluid, then shake, rattle, and roll it until the insides are scoured clean.
You'll probably also need to take the carb apart and clean dirt and old varnished fuel out of it as well, 99% of the problems small engines have are caused by a dirty carb.
Don't be afraid to do the work yourself, just take your time, lay out the parts/nuts/bolts as you remove them, and maybe even take cell phone pics as you go along - they're good reminders of what goes where when you're reassembling.
momoe
thanks guys and u jamyes man,lol i was about to say ahhh ill just take it to a mechanic ... and ur like dont be afraid to do all the work,, when i get back home ill try to figure out how to take the gas tank but its waaay early for me to deal with takin out a carb and clean, also cuz this shield thingy has a dull screw... soooo. yah fml
momoe
nothing looks like an oil drainage underneatht it
and i cant take off the gas tank cuz of tht iece of metal huggin the tube
it feels like i bought a ... crime scene not an engine
i'll just go to a mechanic tomorow for everything
Cjhoward78
Pic#1 center, square head bolt sticking straight up= oil drain plug. As for the tank remove bolts holding the hinge to the engine.
jamyers
Buffalo Gap, TX
I can't tell your location from using TapaTalk, but if there's a board member nearby, it'd be a small matter to pop that tank off and change the oil...
Got any friends or neighbors who work on anything mechanical? A 6-pack can go a long way...
momoe
nope unfortunately the closest member to me is from Ontario which is too far away ...
hey guys, will i have a hardtime finding a clutch if my shaft is 2-1/4 " long? ( sounds sooo wrong) and if YES its going to be a problem, how can i deal with it ?
jamyers
Buffalo Gap, TX
Shouldn't be, iirc that's standard. Only think you might have an issue with is that auxiliary-drive shaft, if it sticks out too far and/or if the clutch diameter is too big - but I think a standard centrifugal clutch oughta work ok. Main thing is to get one with the proper shaft size (diameter), and the number of gear teeth you want.
momoe
well are most clutches smaller than or 5" in diameters ?
Smaller than 5". 4, maybe 4 1/2".
I believe that's an old Tecumseh Snow King series. Look for numbers stamped into the metalwork somewhere. Could be an H80.
