Briggs and Straton 5hp noise
EBACH
va
at wide open throttle my motor made a nasty sqreeching noise.:ack2: i shut it off before i tried to see what it was. it had oil in it. could this be crank bearings?? i started it up after it happened and it ran fine at idle and seemed to be ok, but i did not WOT it again. any ideas??
crazy4carts
check the recoil starter clutch, the thing with the little silver balls in it, sometimes they make a really loud screech, and tries to spit the rope out, when it does it. probably just needs a good cleaning, and a little lube, and it should be fine
Do not use a wet lube inside that clutch- they are meant to stay dry. You may need to lubricate the crank snout that the clutch rides on.
It would help. You may be able to get away with large vise grips, a pipe wrench, channellock pliers, or similar. The bigger issue is that without the proper tool, you cannot torque it down to spec.
I have used a chain wrench.
There should be a small hole in the end of the square(ish) post; you may be able to get a few drops of oil in there
crazy4carts
that's true, but as stated earlier, dry lube is the better way, i have used a large flat end punch, and a hammer to loosen, and tighten the clutch, but if you will just take out the 2 1/4" bolts holding the screen down, sometimes 4 screws, you should be able to take a knife and pop it open and access everything, just slowly pull it all apart, clean out the cup area that the balls lay in, take out the square drive unit, clean out the hole, and the shaft. i use white graphite to lube mine, and slide it back on the shaft, and it should spin freely. a little shot of lube in the assembled clutch, and slide the cover back on. if you're careful, you should be able to sit the little balls in each one of the areas, where they belong.
It is definately your starter clutch. The lubrication inside the clutch deissapears, and it starts binding. If you don't sort it out soon, your starter will bind, your spring will get all twisted up and you might have to replace it.
There is a really good video by DavidsFarm where he shows you how to lubricate it. He used transmission fluid for lubrication.
EBACH
va
cleaned the inside of the starter clutch without having to remove it. looks like it fixed the screeching noise. for now anyways. but at least i'll know what to do, if there is ever a next time. hopefully not tho.
THANKS GUYS!
jamyers
Buffalo Gap, TX
Yeah, when they really let go you can get an impressive shower of sparks flying around inside the blower cover...not to mention the ear-splitting noises...
:wai: There is no spring in that clutch, as it is not a cup type.
Is there some sort of magical rope "Bringer-backer" other than a spring? No- the spring is NOT in the clutch, the spring is in the same place it always is- in the recoil assembly. Cup or no cup. If that clutch seizes, goodbye spring. :wai:
Yup, I have never seen a starter recoil without a spring. I guess that is why they call it a RECOIL
