GX140 back fires!
Aazza
I've just brought back to life a Honda GX140. It was out of an old Wacker plate. The spark plug had been left out and water had gotten inside. I managed to free the piston and honed the bore, replaced the rings, lapped the valves, cleaned the carb, replaced all gaskets, new oil and generally cleaned the hell out of it.
Just got it started for the first time and it back fires real bad. At mid revs it's almost constant back firing.
Any ideas what could be causing it?
Would I be right in thinking a back fire is fuel igniting in the exhaust?
Cheers
Az.
Aazza
Is it just a case of playing with that screw till I get it right? I've got it set to the standard 5/8 of a turn out. Any idea would I need to screw in or out to richen the mixture?
Would making it even richer not be throwing more fuel at the fire, so to speak?
Depending on your model of engine, you most likely don't have an adjustable high-speed mixture screw. A couple things to check-
*Are you sure you timed the cam properly
*Is there any chance the flywheel (timing) key is sheared
Is it backfiring out the carb, or is it coming out the exhaust?
Aazza
The manual calls it a "PILLOT SCREW" and it adjusts idle speed. Is this the screw?
Yes, when I took it apart I made a video of the inside so I knew how the timing went. I also searched out a PIC online just to make sure it was right before I stripped everything out.
No chance at all. I've had everything off this engine, cleaned and rebuilt everything. So I know it's intact.
Exhaust.
Cheers
Az
Have you looked at the spark plug to see what it may have to say?
No- that pilot screw only affects idle and very low throttle. And adjustable main is very easy to identify. Look at the bolt that holds the carb bowl on. If it's a plain bolt, then no. If it has an adjustment screw going right up the middle of it, then yes.
Aazza
Okay so it has no adjustment screw then.
I haven't looked at the plug since it ran for maybe ten seconds. I was too worried about all the backfiring to mess with it for longer. Would the plug show us anything having only run for such a short time?
Thanks
Az
Probably not, but it's worth a look anyway.
Regarding the timing key- I have no doubt that you took the flywheel off, and put it all back together, key intact. Did you torque that bolt to spec? If it's a wee bit loose, the key can shear when starting. It may be worth your while to remove the bolt again and inspect.
Aazza
Just been out to look at the plug and it's still brand new, no tell tale signs.
The flywheel was indeed torqued as per the manual. I think 70nm off the top of my head.
I'll pop the flywheel off tomorrow if you think it's worth it. Can't start my compressor this time of night to use my gun, neighbours probably won't appreciate that one.
Cheers
Az
DJEEPER
Any time you mess with your intake or exhaust you are changing the air fuel mixture. Opening up your exhaust or intake will make it run more lean. Just like any restrictions in intake or exhaust will make it run rich.
Try blocking off part of the intake and run the same as you did before. See If there is any difference
Aazza
:oops: I may have been running without an air filter :oops: Would this be causing the problem you are talking about? I'm waiting on a new filter, the old one would do more harm than good...
DJEEPER
It would cause it to lean out if you don't have the same restriction that they engineered the engine to run with.
Aazza
Cool, well the new filter is on it's way. When it turns up I'll try again.
Cheers
Az
To eliminate a lean mix caused by a missing air filter or partially clogged jet, try running with the choke partway closed and see if things improve.
Aazza
Just run it up with a cheap K&N lookalike air filter on it and it run like a charm. I've got a feeling that the backfire was fuel not burnt off from previous start attempts and if I'd let it run for longer it would have been fine anyway.
Anyway I'm pretty happy with it. Cheers for your help people. Now I've got a running engine I can move onto my mini buggy build.
Cheers
Az
Aazza
Good luck with the build... Contest?
I had thought about it, but I don't want to rush it. Giving myself a dead line isn't what my little build is all about. It's my first build and I really don't have much time or the funds for a rush project. My next project before the build is a tube notcher. Once I've cracked that, I'll make a start on the buggy.
Az
