Exhaust
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
The pop is caused by extremely lean combustion chemistry when the throttle plate slaps closed. Lean a/f mixtures burn slower, thus the mixture is still burning when the exhaust valve opens, emitting said pop. Many carbureted vehicles use a "dashpot" to prevent the throttle from closing too quickly, though mostly for emissions purposes.
zbuck
Ft. Wayne, IN
:wai: Is that engine a Honda/Clone? Is the exhaust port d-shaped, We fab a exhaust header flange (d-shaped) do a little mill work to it, to transition the outlet side of the flange to round, therefore leaving the d-shape next to the exhaust port.
jamyers
Buffalo Gap, TX
Just an fyi, shorter pipes are better for high (above 3K) rpm, longer pipes are better for low (below 3K) rpm. My governed Briggs 8hp flathead has a 2.5-foot-lond straight pipe that makes a noticeable difference over a 6-inch pipe, for example.
Since you're dealing with EMT, you could make a loop (or two, even) and have an effective long pipe in a small package. Either use a bender or weld a bunch of 90*'s together...
peterbilt
Denver,Co.
So if said engine runs at 3600 rpms without the governor removed, then say a 6" pipe would be ideal for good all around performance?
zbuck
Ft. Wayne, IN
:wai: Just to expand on what Jamyers posted. Longer lenght=more botton end/larger dia.=more top end. Shorter lenght=more top end/smaller dia.=more bottom end. The best way we have found to determine lenght is, leave the pipe long and paint it, where the paint burns off is the lenght we cut it to. Either way you go,be sure after shutting the engine down, either bring it up on TDC or plug the pipe end. This is to keep cold air from entering the engine and warping the valves.
For the record- to date, I have not heard of nor seen any examples of valves getting buggered up by using a short straight pipe (open header) on a small engine.
It is my personal belief that this is basically bunk. That section of straight pipe gets pretty dang hot. When you shut down the engine, it remains hot for quite some time. Any air flowing in and around that pipe is heated by the pipe, as it gently and slowly cools.
It might be a different case if you ran no pipe at all...
zbuck
Ft. Wayne, IN
I am glad that is your personal belief. Here in the lower 48 it is common knowledge amoung racers to either pull the engine up on TDC/plug the pipe after a short cool down period. Sure, either a long or short pipe will stay warm/hot for a short period. Therefore building more heat in the engine after which normal thermodynamics will pull cool/cold air into the engine.
I really cannot prove or disprove the theory. What I am saying is that I personally have seen no evidence of the suspected problem. LOTS of people run short straight pipes, yet I've really been witness to no first-hand evidence. One thing-
"Common knowledge" is not necessarily truth. As an example- it is "common knowledge" that if you yank the governor out of your engine, your flywheel is going to grenade, and kill every living thing inside a 50-mile-radius... Yeah.
Not saying you're wrong, just saying that I have yet to see any evidence- including my own experience. I run in cold climates- talk about your cold air getting to an engine!
Cjhoward78
I'm just curious! My experience building small engines is limited but I used to build 4&6 cylinder turbo engines pushin 20+ #'s of boost w straight pipe out the fender. And I never had valve warps. I have blown/burnt engines in ways most people have never seen. That's a whole nother thread tho. There's a lot of tricks to the trade per say so I am curious if this is accurate info that I should be adding to my skill set:) thanx
jamyers
Buffalo Gap, TX
I'm my not-even-humble opinion, a 6" pipe is too short - most every racing (5000+ rpm) pipe I see looks like 6". Plus, I've done the painted-pipe thing a couple of times, on a decently-tuned governed engine is seems that 12-18 inches is the point.
Personally, I like using at least 3/4" EMT, as long as I can go, at least 18-24". My 8hp flatty's uses 2.5' of 1" EMT (and needs a muffler, my ears hurt).
Cjhoward78
I like this, gonna loop mine like u mentioned to attain about 18" and see how it does
zbuck
Ft. Wayne, IN
Zbuck, have u experienced a warped valve due to regular heat transfer?
Yes, several times. It usually happens with rookie Fathers not having a clue. They go out and buy a racing kart ready to go and think they know it all. I myself have had it happen. Have you ever been to the drag races and after a brief cool down they cap the headers? Back in my day, wether it be stockcar/drag racing they used to use tennis balls to plug the headers. In some people estimation that is where the idea to plug the header on kart engine came from.
Perhaps, then, the problem is more specific to the extreme conditions faced by race engines. If it's a common practise, and you have experienced it, then so be it. But like I said, in our applications it is not something you hear about, or see.
What do you think is the major factor? Race engines running significantly hotter?
