T-Bucket style Go Kart
zbuck
Ft. Wayne, IN
:wai:IceMan 198753, If I was puter savy on posting pictures. I'd post one up. Triangle frame is the same as a wedge frame. On the rear axle, I would use 1 1/4" gun drilled axle. On frame dimensions, you have to take into consideration, your size (leg room) and the size of engine and tranny and go according
You might run into lubrication issues with the rear in that orientation.
Agreed. When you point the yoke straight up, there is NO lubricant getting to the pinion shaft bearings. Won't live long. This same concern exists when lifting live axle trucks. You want to rotate the pinion upward to reduce the angularity of the U-joints, but there is a "point of no return".
Also, an automotive diff is going to be a serious anchor- narrowed or not.
IceMan198753
Kansas City, MO
Sorry guys I haven't been on for a few days! I just got back home from being out of town with work. I will try to get some pics of the engine up tonight or tomorow. Thank you all for your input.
IceMan198753
Kansas City, MO
Well I have been talking with my local lawn mower guy. He said I could use a transaxile and change the input pully to get my speed I wanted. I would have 5 forward gears and 1 backup gear. Also put an idler pully between the engine and rear end. AND its a big AND, he said it was about 100 dollars for the whole transaxle. What do ya'll think??
IceMan198753
Kansas City, MO
Here is the big beast!!!:wai:
Fired it up tonight and it runs good. Might have to gap the valves, it back fires when going from high throttle to low throttle quickly.
IceMan198753
Kansas City, MO
So the next thing I have been thinking about is the steering system. I would like to mount the steering wheel in the middle and then go down to the driver's side wheel. I need your help to figure out what I need to design and/or make to make this possible.
Depends- are you talking about reworking the whole schmeer (like you should) or do you plan to make use of the existing components?
silver tucky, IN USA
yeah i know its a front engine kart been watching this one. you could route the shaft around the motor then bring it back to center idk if they make an offset rack you could poss pull one from a car
I apologize. I confuse your build with somebody else's.
Anyways- I have had to put a lot of thought into it myself- one possible solution is a system of linkages that would sorta mimic a real rod. The steering column itself would only be a few inches long, enough to protrude through the dashboard. Just on the inside of the dashboard is the pitman arm. The pitman arm points straight to the right. A few inches below that, is a shaft that runs horizontally, the entire width of the body (this shaft is behind the dash, and therefore not visible. The pitman arm is connected to this shaft via a short rod, and an arm on the shaft which points straight forward. On the right hand side, the shaft rests on a bearing, and does not protrude through the body. On the left side, it passes through a bearing, through the body, and features a downward-pointing arm OUTSIDE the body. From that arm, a drag link runs towards the front of the kart, connecting to a steering arm on the left-hand spindle. This arm would come off the spindle, parallel to the front axle (pointing straight right). Of course, the two spindles would be tied together with a standard drag link and steering arms.
So- When you turn the steering wheel, the pitman arm moves up and down. That in turn moves the first rod up and down, causing the horizontal shaft to rotate backwards and forwards.
This causes the arm outside the body to swing back and forth, moving the drag link back and forth. That, in turn, causes the steering arm to swing the LHS spindle left and right.
