Replacing a broken stud - The HARD way
As most of you know, I recently aquired a Marshin 150cc pitbike engine. Apart from the severely messed up wiring, the only problem (visually) with it was a broken exhaust stud.
I will now apologise in advance for the lack of before & early pics as I didn't know this would become as big an issue as it did.
So, I started out the usual way, drown the broken section in penetrant, centre punch & drill the centre with a 1/8" drill bit.
Then, after spraying even more penetrant, I hit it with the stud extractor. No joy, it wasn't budging. Worried that I would break the extractor (I've done that before) I drilled out the hole to the next size up. Unfortunately, I hadn't drilled deep enough so, I kept going: That's when it all went horribly wrong!
Instead of drilling straight, the drill went sideways towards the exhaust port. Worried that I would do irreparable damage, I stopped, rang a couple of mates for ideas/suggestions & rethunk the situation.
Here's what we came up with:
It's a drill guide! :D
After measuring the dimensions of the now messy hole I hit the lathe. One end is an interference fit to the hole in the exhaust flange, the other end is larger (so it holds against the flange) & tapers down to the size & depth of the stud hole & is hollow through the centre.
Once I bolted the flange in place using the good stud, it gave me a perfect guide to drill the old stud out. Once I had a perfect base guide, the rest was easy
Once I had the guide hole where I needed it, it was clear I'd need to increase th size of the thread; from 6mm it ended up at 10mm.
I did make up a stud 10mm on one end & 6mm on the other but, the 10mm end is too short & sinks into the head too far :censored: so, back to the drawing board :mad2:
realfast89gt
Kart Krazy!!
cibolo Tx
Man, i know how that stuff goes. Last thing like that i had to fix was a spark plug in a ford v8 that broke and left only the threaded part. As long as you take your time and use a little brain power it normally goes well in the end.
Done!
I got back on the lathe today & spun up another stud.
For those interested, I started with a length of 12mm round bar & cut 2" down to 10mm then the 1" on the end was cut down to 6mm. A 10* taper on the end & at the step to help start the dies, cut the threads &, finally, even out the taper at the step.
I made sure it was tooo long this time; it's easier to cut it off than add it on. A few trial fits, a bit of cutting & grinding & I'm done!
Who can pick it?
fowler
Bullsbrook West Aus
good job
it certainly helps to have a good pool of resources and knowledge
dam these things are a real pain
i have gone though this with a D 10 dozer
started with a simple heat sheild change
found 4 brocken exhaust studs and the others were rusted to non existance
fixed them all then snapped the tap in the last hole
had to blow it out with an oxy
Oh, FUDGE!
That's something that truly would wreck my day, breaking a tap off in a hole. I am not equipped to deal with a disaster like that...
Nice work, Tony- boy, you really cut it close with that one, didn't you? I just noticed the "hole in the wall".
fowler
Bullsbrook West Aus
Oh, FUDGE!
Wow I see what u mean
Bloodly close
At least it's in the outside and not going to cause any sealing problems
Bet u were nervous when u tapped it
As for breaking a tap
I was only a 1st year and did it in a head worth 10s of thousands of $
I was s***ing my self alright
cumminsbayou4x4
fairhope alabama
i broke a tap off in my 3hp briggs crank shaft. i was doing it with no help and it was the first time id used one. when i did it i thought ill have to get a new crank shaft .then i thought why not weld a bolt to the end of the crank shaft and double nut the clutch on it. this worked great its straight and i have used it a lot with this system on it
Rustydog2010
NZ Nutta :|
New Zealand
Oh, FUDGE!
Just on this. Have you heard about tap extractors? I found some in the W/S and had no idea what they were at first. When I used them they worked great. The flutes goes down beside the cutting edges, and you just unthread it.
Thats an awesome idea Fabroman. Making up that guide is what I call thinking outside the square. :thumbsup: Might have to urmm... borrow it! :cheers2:
