Commet 40 What belt do I use?
MikeM101
Florida
:welcome2:I have a Yerf Dog Model# 3202:auto:
I lifted it and made it Alot heavier. With bigger tires and what not.
Engine: Honda GX340
I have the Commet 40 Driver and Driven T/C costed me around 400 bucks! :mad2: So needless to say I really need to get this running after all that Ive had to Invest. Please help me out.
I need to know what belt to use.
How far to weld my jackshaft with the driven/
from the Driver mounted on the engine.
I was told specific belts for this T/C would give more torque or grip than others.
Can someone explain the art of which belt I should use Im posting up pics in like 5 mins. Please a thank you I love you all. HAHA
Ive been working on this project for over 2 Years :mad2::mad2:and spent around 700 bucks on it so I would really love it to ride perfect.
I don't know where this came from, but I call B.S. on it. A properly fitted belt of the appropriate specs is a properly fitted belt of the appropriate specs.
Have a look at this Comet belt chart- http://www.bmikarts.com/PDF/Comet_40series.pdf Note the belt chart on page 3. Install your jackshaft spaced at any one of those measurements, and order that belt. It's that simple. Please be aware that your spacing does need to be accurate for optimal performance.
MikeM101
Florida
What is a speed reduction ratio?
SPEED REDUCTION RATIO
LOW HIGH
1:1 2.43:1
OVERALL
2.43
What does this mean?
That 2.43 is the "low gear". At engagement, it starts at 2.43:1, and works it's way up to 1:1, being the high speed ratio. Beacuse it caps out at 1:1, it stays invisible in your gearing calcs.
