Tecumseh Carb Replacement/Upgrade?
GoodWComputers
Aspiring Mow-Kart Owner
Oxford, Ohio
I've searched all over the forums and elsewhere online and can't seem to get good conclusive information, so I'm posting here - I need help!! :mad2:
You may have seen the Mow-Kart Project I am currently working on. The new starter arrives today and I should be able to fire up the engine for the first time in a while to see where I stand with my Tecumseh 10 hp TVXL220 engine.
Looking down the road, I am going to have an issue with the carburetor. I am all for cleaning, rebuilding, and possibly re-jetting the stock carb, but it may be pointless with what's wrong with it - one of the air filter/intake screw threads is broken off:
The screw thread on the left appears to be slightly cracked as well. :ack2:
Is there any hope for this carb, or am I doomed to buy a replacement? Looking through parts references and manuals online, I believe I have a Tecumseh carburetor 63290. Brand new replacement costs $80:
Tecumseh Carburetor Part No. 632572 AKA 632690
If I have to replace the carb, what are my uprgrade options? It would seem silly to buy an OEM replacement when there are so many great racing carburetors available. That being said, I've been reading some comments on how the OEM replacement for a small engine is the only carburetor considered best for the engine (designed/tuned specifically for this engine).
Thoughts? Thanks in advance.
:popcorn:
Maybe look onto a Mikuni. That business about the OEM carb being the only thing suitable because it's tuned...blah...blah...blah. Yes, and No. Yes, it should be ready to go, right out of the box, sized and jetted for your engine. On the other hand, a really good carb like a Mikuni is VERY highly tuneable- and as long as you select the correct venturi size, you're good. Tuning that Mikuni to suit your engine will yield better results in the end than the stocker. The stock carb has two circuits. Idle, and high speed. Since there is a large range of throttle opening and engine demand between idle and WOT, it's a compromise. A Mikuni, on the other hand, has 5 stages to it. Tune them correctly, and you will get a better mix throughout.
I want to know how hard somebody horsed on the air cleaner screw to do that damage!
You could consider cleaning the heck out of it, building them up with JB Weld, and redrilling the holes.
GoodWComputers
Oxford, Ohio
I checked out Mikuni's web site but didn't find much help there in regards to getting a carburetor for my Mow-Kart. How would I know which model of Mikuni carburetor to get?
I don't have much experience selecting aftermarket carbs. I would think that the best thing to do is measure your current venturi diameter, and order one with a similar spec.
JB weld is an idea, if not a band-aid.
An other Idea if you are keen on that Carb besides buying new, Take that(albeit Cleaned very well and without any parts) to a good welder that does intakes or the like for cars and other vehicles. He would be able to weld up the holes and make you a new base to reshape and drill/tap with out spending too much(Im thinking), some persuasion with drink or other gifts, a ride on the completed machine also helps too.
GoodWComputers
Oxford, Ohio
You beat me to the punch. A buddy and I were talking about this option tonight - I'm going to eventually put on an aftermarket air filter anyway, so we discussed either buying an air filter bracket/adapter and having that welded on, or just having a local shop weld on a short piece of pipe, and attach the air filter to that.
qtband
St. Louis, MO
I've had both of your issues. I needed a Tec carb and had a broken screw hole.
Either JB Weld product will work as long as you clean it well! The Steelsink is more like a putty and will be easier for you to use. Let it sit a day before drilling it. It will work fine.
As for a carb, I used a cheap clone carb (slide type) from Ebay on my 3.5hp Tec. As Toystory said, measure your venturi and get something close. I had to elongated the carbs mounting holes to fit the Tec but that's not a big deal. It worked really good!
Something like this:
http://www.ebay.com/itm/New-25mm-Ca...Parts_Accessories&hash=item4d08bd408b&vxp=mtr
GoodWComputers
Oxford, Ohio
Here are pictures of the air filter side of my carb. I'm not sure what I should be measuring.
You can rejet, but should you? Do the modifications first, and let the engine tell you if it's thirsty. If it does require rejetting, the first step would be to determine the current orifice size.
GoodWComputers
Oxford, Ohio
Gotcha. I was doing some research this morning and saw several guys that went ahead and replaced/resized the jet at the same time they upgraded their exhaust and air filter... some had to go back to stock. Good call!
Yes. I get annoyed when I see people saying that a) You MUST rejet after these mods, and b) buy a size "X" jet. Nope. too many variables.
realfast89gt
Kart Krazy!!
cibolo Tx
I agree with waiting as well. I bought 3 jets(37,38,39)for my carb after installing an air filter/header/cam and tryed it out first. Runs great with the original jet, too rich with a 39 jet, going to try a 37 next.
I read multiple places about people saying to change the jets after these mods, but it obviously is a case by case sort of thing..
GoodWComputers
Oxford, Ohio
I think I'm going to buy one of those drill sets so I can resize the jet myself. You guys have any experience doing that? Would buying several jet sizes equal the cost of the drill set?
qtband
St. Louis, MO
Good choice on rebuilding that carb. While you are waiting for it, JB Weld & fix that broken screw hole after you clean the carb, and you'll be ready.
jamyers
Buffalo Gap, TX
That sure looks like a Walbro LMT or LMK carb, if it is then it should be marked somewhere under the crud.
Regardless of the maker/type, if the main jet is located in the bottom of the center "tower", you can convert it to an adjustable-main-circuit-type by either buying or making an adjustment needle that goes through the bolt that holds the float-bowl onto the carb body. See this thread
