brister chuck wagon cvt
smgs92
I plan on throwing more power than I think a 40 series can handle. Stock my engine is 16hp it's going to make around 30hp I don't trust a 40 series to take that kind of power.
I was hoping this CVT would hold up because its a bit cheaper than a snow mobile torque converter which is my other option.
smgs92
I have thought of it but I was wanting this to work cause its alot cheaper hahah
Kaptain Krunch
Pro Junk Collector
vermont
good luck making a snowmobile clutch fit. First off, all tapered bore. Generally 30mm. Second, designed to engage at 3500 or 4000 rpm and fully shift out at around 6-7 grand. Obviously you could change weights and springs in both primary and secondary but it would end up being a huge PITA.
As far as the 40 series holding 30hp, it may it may not. I would be most worried about secondary clutch and belt wear, primary should handle it. Have you considered just using a sled engine if you want that much power? likely cheaper to buy a whole sled than modify that 16 horse and buy a torque converter.
fowler
Bullsbrook West Aus
The comet 40 will do up to 25hp
It will proberbly do 30hp
But if u ate modding a 16 hp into a 30 then firstly u are proberbly not going to actually make 30 hp
Also u are pushing the engine to a certain point with mods like a bigger cam and hi flow exhaust ect
Then quite a lot of power comes from the extra rpm
So your engine may make 30hp but not be pushing the torque of a 30hp engine
Torque is what will kill the belts
So my thoughts
Yes u could use a comet 40 safely but at the top end of its range
smgs92
I found an adapter here so connecting a snow mobile CVT will be no problem.
http://www.cartpartsplus.com/tapered-clutch-adapter.html?osCsid=e4ce4264646da5a4dd208bb332e48c49
I've considered a sled engine but I already have this engine and it has TONS of aftermarket parts so getting that kind of power is no problem.
I'll be adjusting when it engages, thats one of the main reasons I want to run the sno mo clutch. I like how adjustable they are .
So my thoughts
these engines can push 45-50hp if you build them enough and they can turn 10,000rpm's. I'm not going to spend that much on it though. My goal is 30hp and 8000rpm's.
Kaptain Krunch
Pro Junk Collector
vermont
Not to rain on your parade, but even tho you already have the 16hp, it would still likely be cheaper to buy a sled engine than modify the 16hp. However, if the fun of modding is what your after and money is not an issue have at it. I'd run a sled clutch if thats the route you choose, simply buy a primary clutch that needs a rebuild and buy a rebuilt kit with the right weights, rollers and spring that you need for your desired engagement.
smgs92
It would be but I see everyone do that I want my kart to be different. and that sounds like a good idea, a snow mobile clutch is my plan.
