I'm back and have a new engine to play with!!
realfast89gt
Kart Krazy!!
cibolo Tx
I recently bought the new predator 7.0hp 212cc engine and sold my tec 6.5.
My mods are in the mail and are:
ar3910x spark plug
10.8 trick valve springs
140 emulsion tube with a variety of main jets
bsp-2 camshaft
rlv header
kn cone air filter with adapter
2 and 4 degree offset timing keys
My question is for anyone that has knowledge of these engines. I plan on getting bilet rod/flywheel, but until then i will not remove the governor.
Am i forgetting anything that i will need or that is recommended with these parts? I want to make sure i dont have any issues. I use this for offroad use, lots of corners and drifting, so my goal is beter hp/torque so i do not lose as much speed around corners.
Thanks for any replies
:wai:
realfast89gt
Kart Krazy!!
cibolo Tx
Yes, but not until the billet rod/flywheel. I am too cheap to put $250 into an engine and have it explode due to stupidity.
realfast89gt
Kart Krazy!!
cibolo Tx
I hate swipe.....had too many times when it changed the word without me knowing...
So anyways, anyone use the bsp-2 cam on a predator?
smgs92
i have that engine with
18lb valve springs
1:3 rockers
gx160 rods
rejetted
throttle spacer with pulse fitting
uni filter
arc aluminum flywheel
8degree key
custom exhaust
walbro fuel pump
removed governor and i think thats it but i'm probably missing something but this thing is mean!
i plan on getting a new conrod and cam so it really flies and is bullet proof
realfast89gt
Kart Krazy!!
cibolo Tx
18lb valve springs
1:3 rockers
gx160 rods
rejetted
uni filter
8degree key
custom exhaust
walbro fuel pump
Sounds good, i am trying to make the predator put out enough torque/hp to drift corners and not lose speed coming out of the corners like i do with it stock. I just ordered the cl-1 improved cam that nr racing suggested. I want this to be reliable and still idle well which is hopefully what i will have when i am done.
Which arc flywheel do you have? I will be getting arc flywheel and rod eventually, but too pricy right now.
realfast89gt
Kart Krazy!!
cibolo Tx
Also does the fuel pump make that much difference? I havent been able to find when the fuel pump is a needed item as far as upgrades go.
smgs92
http://www.nrracing.com/product-p/6619-25.htm this is the flywheel i have.
and you'll notice a huge difference in response and before when all i had was an exhaust jet and intake on my mini bike it hit 28mph after it hit 45mph with room to keep going.
and the fuel pump isn't really needed until you start building it up to decent power +20hp mine runs fine without it.
and mine runs very reliably and it idles just like when i bought it and you should have plenty of power to drift.
