Nodroz
Hello,
I just bought a multifunctional welder that is able to weld MIG, TIG and with sticks.
Now I'm experiencing some problems with the settings. I've seen a lot of videos on the internet where people have a chart of the basic welding settings on the inside of their machine. I don't have this. There's also nothing in the manual about the settings whatsoever.
Now my question is, is there any general saying to know how much volt do I need and how fast my wire speed should be?
When do you know if you're welding too cold or too hot?
When do you know if your wire speed is too fast or too slow?
I read that you need 1amp per 0.001" thickness. Is there any similar trick for the voltage and wire setting?
How much flow rate do you need for welding inside a garage with the door open. Almost zero wind is coming there. Do you need to adjust the flow rate of the gas when welding a corner / overhead / horizontal / overlapping / butt joints / etc etc ?
Thanks in advance,
Alex
Thanks in advance,
Alex
