The worst valve I have ever seen.
crazyman
Yorkville Il
From a later Robin/EZ-GO head, both intake valves...
beansdaddy78
JR. Member
Carbondale IL.
the worst i have seen was the one were i was off in la la land and stuck the wrong sparkplug in and tried to pull the he!! out of it but it seemed locked up :p
but the plug was catching the valves, and unfortunately i was wearing my shirt with the muscles in it becuase i snapped the exhaust valve and bent the intake. I hadnt noticed the intake was bent and when i got the new exhaust valve i lapped them both and then noticed the intake was bent. the damage has been done though cause now the intake valve wont seat properlly.
Anybody know if possibly using a lower grit sand with the lapping compound might help to wear down the valve seat (if thats what the hole that the valve goes into is called :D) enough for the intake to seat properly again???/.
machinist@large
West Michigan, 49331
Do you have a sacrificial valve to lap it with or were you going to use the new replacement? Actually, if you wore it in that deep, you would really need to take it to an engine machine shop that has the tools to relieve the valve pocket and de-shroud the seat area and bring it all back into relationship.
If that's not an option, you'll need at least another valve, with the coarser grade compound to rough it in with; keeping the valve you intend to run for final lapping in with the fine compound. Otherwise, you're back in the same position again.:oops:
It can be done, it's just not as simple as grabbing a new can/ tube of paste and going at it again......:thumbsup:
