Tire trouble
racer454
Im trying to change the front tires on my go kart. I started doing one wheel, got one part of it off then i somehow can not got the other part off!
So Im trying to see the way that people on here take their tires off of theirs.
Oh and the tires are thick/stiff and ive tried just prying at it and pulling like on the other part... it just doesnt want to work. So can someone please help so i dont have to bring them somewhere to get them changed!
The top tip I can give you straight off, is to start with a warm tire. Leave it to sit in the sun or with a heater pointed at it for awhile.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Also, when trying to pry up the second bead over the rim, tip the opposite side of the tire up while working the lever under the bead. Once you'e got the lever under the second bead, pry it up and over the rim while letting the opposite side of the tire fall. A search on Youtube should yeild a few dozen how-to's.
Warning: Shameless self promoting plug coming:
Make yourself one of these :D
In the short term, you can use a piece of rod or tube mounted in a vice & use a pair of large screwdrivers to lever it off.
Watch this video from about the 1minute 40 mark to get the idea:
Maybe we should sticky that thread :innocent:
jamyers
Buffalo Gap, TX
Fabroman, that's friggen' ingenious!!!
Racer454, keep in mind that the key (whether you're using gear like fabroman's, or several long tire irons like I do, is to make sure the bead on the opposite side is "down in the well" of the rim, because you'll never stretch the tire's bead enough.
devino246
Lynchburg, VA
:lolgoku: That comes from years of struggling with car tyre machines:
If it don't work, improvise :D
You should see the one we have at work. Hardly have to lift a finger, much less a tire iron. Has a pneumatic 'finger' that pulls the bead off the rim for you.
