Manco Robin Suburu engine
Sparky723
I have a Manco Fox Conquest go cart.
It has a Robin Subaru 5hp 126cc engine on it.
It will start ok (4-5 pulls), but when I drove it, it will go for about 100 feet then practically stop. If I let of gas pedal to about halfway, then it will start going fast again. It's like it's disengaging the belt or something.
It also leaks gas from below the carb bowl and the exhaust spits out oil.
I have been talking to a senior member who has been very helpful so far. He suggested I clean the carb.
I will post pics soon.
jamyers
Buffalo Gap, TX
Howdy, and Welcome to the forum!
To post pictures;
If you want to post pics, you'll need to one of three things.
1) If you're posting a new thread, just scroll down and look for "manage attachments". That's it.
2) If you're replying, click "quote" and you'll get to the right window.
3) If you're "quick replying", just click "go advanced" at the bottom of the page, then scroll down to find "manage attachments".
You'll get a pop-up and be able to upload photos. When you're done, click "close" and the photos will be attached to your post.
More detailed info and some other options are in this thread: http://www.diygokarts.com/vb/showthread.php?t=19607
jamyers
Buffalo Gap, TX
I'm assuming that you mean that the engine is cutting out, not that it's revving up with the kart slowing to a stop.
jamyers
Buffalo Gap, TX
Stuff that I'll bet you'll find helpful;
http://outdoorpowerinfo.com/repairs/subaru_robin_mikuni_27x-623xx-xx_carb.asp
http://www.gokartsrus.com/product_info.php?products_id=5007
Check out the "Cross-Reference Model Name to Model Number" link, as well as the engine and engine parts manuals. It'll be helpful to know the exact Manco model number if you ever need parts for the kart, and if you need engine parts it's best to search / order them by the specific model / series numbers, if available.
Here's the single best karting-info thread on the internet, well worth a couple of hours of your time: http://www.diygokarts.com/vb/showthread.php?t=10036
About a third of the way down in there is the thread on using lemon juice as carb cleaner.
Sparky723
Right, after the initial full speed for about 5 seconds, it does not rev up when trying to stop.
jamyers
Buffalo Gap, TX
OK, Sparky723 and I spent the morning cleaning his carb, here's my report.
Subaru EX13 engine (129cc, 5hp) on a nice Manco "short-person" kart with Comet tc. :thumbsup:
Even though Subaru put the idle mixture screw on the engine side of the carb where you'll never get a screwdriver on it, and even though they put a limiting cap on it to keep people like me from messing it, that's no excuse for me breaking the idle mix screw off in the carb trying to get that stupid limiting cap off of it! :censored: Grr, how stupid and embarassing of me... although thanks to my pile of spare carb bits I had a screw that worked, even if I did have to re-tap the threads in the carb. (sigh...)
OK, so after fixing my screw-up, the carb didn't appear too terribly dirty, but we sprayed it out and gave it a hot lemon-juice bath anyways. The float needle looks ok, but after putting it back together it is still leaking. :mad2: Anybody who has a line on a carb kit deal, please let Sparky know.
Cleaned it up, put it back together, and it started right up on the first pull, YAY!
Sparky took it for a drive and it seemed ok, then all of a sudden it let out a HUGE cloud of white smoke and the engine stumbled, then it cleared up and seemed ok again. Made me scratch my head - I'm thinking rings, maybe valve guides...but then they'd be continuous, not intermittent...
Did some poking around, and checked the oil level - and an amazing amount of oily gasoline ran out of the crankcase!:smiley_omg:
Apparently the main issue is a leaking float needle valve / seat in the carb, which let fuel flood into the cylinder at rest, which then made its past the piston and down into the crankcase, where it raised the "oil" level to an amazing level, which the running engine would then ingest - and either flood or foul the spark plug, making it cut out either way.
Sparky had to head home, but the plan is for him to get a needle and seat (are these carbs' seats replaceable?), change the oil, and I'm thinking he'll be in good shape.
Anybody else have any ideas - I am SO open to suggestions...
Najuto9tail
A friend of mine with a (honda gx200) changed his carb for a car's carb. He had to add a manifold which converts the small size to bigger size and we gave it some tunning and it works great.
I found this parts on ebay do not know if they will work or not
http://www.ebay.com/itm/Robin-Subar...992?pt=LH_DefaultDomain_0&hash=item35c2522cb8
http://www.ebay.com/itm/Gas-Subaru-...DefaultDomain_100&hash=item43b315e092&vxp=mtr
I had some problems on mine (Robin Subaru EX17 6.5hp) in which I had to let the choke opened for it to run properly it turned out that the air filter decomposed and parts fell into the carb and I cleaned the carb with carburetor cleaner and sealed leaks with silicone and turned it on. The spark got damaged, replaced it with a new one. Pulled it and turned on in first pull. Motor went crazy lot of power on start and then the muffler gave some explosions and the motor then started to work as new. :)
Sparky723
A huge thanks to jaymers for all of his help.
And get this everyone, he did it for $0.
I did not know this was possible anymore.
Nobody does that.
Not only did he spend the better part of 3 hours cleaning and tweaking on my kart,
He has stayed in touch and working online to help me resolve my problems.
He's a friend of a close friend so I consider him a new friend.
I appreciate jaymers help and ANY help the DIY GK forum mbers can give me. I truly appreciate it.
Nobody does that.
Thats what this community is here for. "But if you want to compensate us a little on the side, we won't say no.......ha ha"
jamyers
Buffalo Gap, TX
I'm glad to help, plus I've always figured that what goes around comes around - like dallascowboyfan on here who's sending me a brake cable for the cost of postage! :thumbsup::thumbsup:
I'm just astonished at Subaru for NOT selling carb kits - and their insanely high carb-parts-prices! Maybe the reason we don't see more of their well-designed, well-built engines is because "what goes around comes around"??? :rolleyes:
Sparky723
Update:
I tried the float needle test and shaking the float in my ear.
The needle sat-no gas flow.
The float was silent-no gas in float.
I put it all back together-TIGHT!
Then I changed the oil,spark plug, and gas.
I then open throttle screw all the way and put this fat guy of 225 on it and spent about 20 minutes tearing up a friends pasture.
That kart responded to everything I asked it to do.
Upon stopping, I checked and not one drop of gas and while running, no white smoke or black oily mess from exhaust.
I can't WAIT to give this to my boys.
Now all I'm missing is a new orange bike flag. Need one bad if anyone has one.
