Torque converter Question
jayden727
To all of you who always help, THANKS!! Need help again. This time I have a carter gokart with the 3/4" jackshaft. I want to put a torque converter on it but most are 5/8" driven. What are my options here?
jamyers
Buffalo Gap, TX
Either have the end of the jackshaft turned down on a lathe (then recut the keyway and end threads), or replace the jackshaft and bearings.
Comet 30 series? Their driven units are available in either size, perhaps you could find somebody who has a 3/4" to swap with...long shot, I know...
Probably much easier and cheaper to change the jackshaft and bearings.
Option? Shop for a Comet Tav2, or chinese knockoff. They are mounted as a unit directly to the engine, and include their own, integrated jackshaft. You would take your existing jackshaft off the kart, and- well basically use it to keep papers and receipts from blowing off your workbench when you open the garage door...
jayden727
Thanks to both replies!!! I guess the second one was what I was thinking, but I still need a jackshaft because my chain is on the opposite side of the Torque converter on the axle. This is my main problem.
jayden727
I know you guys like pictures and I can understand why. Im just not great with computers. SORRY. It is the carter trailrunner with double band brakes on the axle.(if that helps at all)
jayden727
If i get a TAV2, Cant I use the jackshaft just to run the chain?
I would need a yerfdog style jackshaft at least 8". What do you think?
Im just afraid the TAV2 wont fit right (in the driven section) because the jackshaft might be in the way.
I don't understand why you're insistent on keeping your existing jackshaft. Take it off, mount up a TAV2, move your sprocket over, and away you go. Having the extra jackshaft on board adds weight, complexity, potential problems and drag.
jamyers
Buffalo Gap, TX
I think it's because his rear axle has a differential, and he can't move the axle sprocket over.
Maybe do what you're suggesting and move the Engine/TAV over to match the axle sprocket?
jayden727
I didn't want to move the sprocket over because l have band brakes in the middle and l wouldn't know where to start. I just ordered a 3/4" driven to make it easier on me. My son is dying to ride!!(me too) lol. Thanks for all the help, we really appreciate it!!
Could you remove the axle, flip it over 180* and reinstall? That would put the sprocket on the other side, and if your brake is centred, you wouldn't have to do anything to it! How 'bout a pic?
