direct drive go kart
cumminsbayou4x4
fairhope alabama
Has any one ever made a direct drive go kart that you can push off to start or put it on a block and pull start it ? I'm think of taking a old clutch thats no good and welding it together so its a direct drive. do yall thing it will hold up, will my motor be operating at fully ?
There's a difference between "can" and "should". Why punish it and risk damage?
EDIT- under the right conditions, I see shorn flywheel keys in your future...
All of the above. With the engine permanently connected to the wheels, the shock load of landing on the ground with the wheels spinning is just like hitting a massive rock with your lawnmower blade. G'bye key!
cumminsbayou4x4
fairhope alabama
yeah i dont want to buy a new clutch plus im running 4:1 gearing in my go kart my clutch is slowly burning up and i dont have the money to replace or get a new sprocket
carter
http://www.bmikarts.com/category/Clutches-314
http://www.bmikarts.com/category/Sprockets-651
Stop trying to do things things the hard way, you're just gonna end up trashing your engine and possible hurting yourself.go to the links above, get yourself a clutch, and get a sprocket and gear to at least 6:1 or you will continue to burn clutches in your future. The simple fact is that (assuming you're using a small industrial engine) you need more torque to run that gearing.
I am thinking that going direct drive is definately not going to be as much fun as having a clutch. All the hassle of having the engine stall each time you want to stop. Push starting and hopping in, all the times it is going to run away from you......not my idea of fun!
But to answer your question, yes, you can make a direct drive kart. Just make sure that you weld/bolt your clutch up properly.
Your engine is going to take a bit of strain though
jman231994
Australia
Im suprised Anderkart hasnt been into this yet....but if I'm not mistaken a large percentage of modern race karts are direct drive, requiring a push trolley.
My friend and I knocked together a direct belt drive kart thingy a little while back, it was a 4:1 ratio running a victa 160cc. Whilst it was and is an utterly rubbish kart, jeez did it go. His dad chased him on their quad and at 55kph was getting left behind haha.
We didnt run it for long, but from what I could tell the engine took very little wear, I dont see how flywheel keys go so easily, the flywheel is rather lightweight and any change in its velocity shouldnt break the key unless incredibly extreme. I'd see the conrod going first. But on direct drive you just coast when you back off, engine braking pulls you up, theres no sharp forces acting there. Now if you have brakes....that could be a different matter :lolgoku:
The keys have a tendency to be aluminum. It's an engineered weak link, designed to fail in order to protect more critical, expensive parts. The example I was drawing (lawnmower) is an illustration of this. Should you hit a large rock or maybe a water shutoff valve with your mower blade, the rotating and reciprocating assembly is subjected to one helluva shock load. Ideally, they key shears so that the flywheel's momentum does not continue to try to spin the crank. If it were to continue, the crankshaft would likely twist (and break) or other catastrophic failure.
It would be the same effect having the rear of a kart on a jack, revving it up, and dropping it. When the wheels hit the ground, that same shock load will be transferred to the crank. The flywheel on an industrial engine tends to be a fair bit heavier than a mower 'wheel, so the effect is amplified.
