clutch probs
kbar
i got my kart up and running but i could only start it with the rear off the ground its like its its direct drive now. The clutch wont disengage when ripping the cord. I have a max force cent clutch when i did all my upgrades it spun freely could it be to tight on the output shaft. heres a pic. Whatcha guys think?
DaiSan76
Nixa, MO
When you bolted the clutch on, does it have spacers back there that are the right size, or are the spacers allowing the clutch to be compressed together enough to engage along the face of the clutch instead of around the outer ring?
Agreed- chain looks too tight. If there is not sufficient slack, the bushing cannot spin freely. In addition, verify your idle speed after all those mods.
kbar
idle speed is fine and i have about .5 inch of slack, i think the springs in clutch may be shot, it did sit for a few months i had surgery and couldn't ride it, I just dont want to take the motor off again its a PITA
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Springs shouldn't be shot just from sitting. Idle speed is normally set until dependent of the clutch. How have you verified that it's correct?
