kx125
DS13
Annoying the Neighbors!!!
Elysburg, PA
So I have a kx125 from '91 sitting on my kart right now. It pumps out 35+ horsepower, and I have gotten a brand new fattie exhaust from FMF for it. If I wanted to do some more "aftermarketing" to it what would make the most sense in upgrading?
The stock engine probably already has way more power than your kart can handle.
If you've got money to spend on engine mods, I'd suggest investing in front brakes... :thumbsup:
FatCat
2 stroke Addict!
Ottawa, IL
1. Exhaust
2. Boyesson fiberglass dual stage reeds(your talking fractions of a hp using those expensive contraptions.) Don't mess with carbon fiber ones either. They do make slightly better power for about 45min on a dyno, then it drops right back where the others were. Your engine will thank you when one fails. It'll poop the fiberglass one out the exhaust with minimal damage. Carbon fiber on the other hand can chew stuff up pretty good on its way through. If your in competitive racing I'd use carbon fiber reeds and replace them after each race. If you are racing that tiny edge would be worth the added cost. In a yard cart its just more work and a waste of money.
3. Bust out the dremel tool and some sanding drums. Clean up the casting flaws with focus on the exhaust port. Don't mess with port height or width, just clean up the rough stuff. Your looking to smooth it out. A little goes a LONG WAY here. If your not confident in your abilities I wouldnt do this. You could ruin your cylinder.
4. Bigger carb. Youll lose bottom end but gain up top. If your on a budget or don't want to sacrifice bottom end you could have your carb bored. Obviously this won't add the performance of a bigger carb but they'res power on the table none the less.
5.less restrictive intake(not K+N) with a Uni foam filter. The bigger the better. Gain flow by more surface area instead of less filter media.
6.head gasket. Does this engine use a 3 layer head gasket? If so remove 1 or 2. Check compression. Of your over 160 add a layer. Keep it under 160lbs and run premium pump gas and your well within a safe zone.
7. Rejet and go enjoy your hard work.
P.S. Andercart is right. Spend the money on safety first. Remember, if your alive you can always go to work and make more money to buy performance parts. If you smash this thing into a dumpster at 40 because you didnt have brakes.... Well that's no fun.
FatCat
2 stroke Addict!
Ottawa, IL
Where did you get from? Around here they are all on bikes and are priced high. Can personal water craft engines be use if a radiator and fan are added?
It could be done if you had your mind set on it. Not a good cost effective option though. Your going to run into serious issues coming up with a clutch. If you want big 2 stroke power grab a sled engine. The whole thing. You'll be surprised how many parts you'll steal off the donor sled. If you bought just the engine these accessories can add up quick.
DS13
Elysburg, PA
Well I bought the whole dirtbike for $225 but the whole dirtbike was destroyed except for the engine and key components I have on my go kart. It has 5 speeds and runs on the 2 to 3rd kick.
Amped
Port St Joe, Florida , U.S.A.
We don't see many sleds in Florida. :furious2: But watercraft are everywhere.
Kaptain Krunch
Pro Junk Collector
vermont
That kart looks incomplete? have you driven it yet? if not i suggest seeing what u got before you decide you want more.
DS13
Elysburg, PA
No my kart isn't finished yet but I'm not familiar with dirtbike engines so I was just wondering what upgrades you can possibly do to it.
FatCat
2 stroke Addict!
Ottawa, IL
35hp with gears should get your attention on a go cart. That should be plenty. If not. Go through that mod list I made for you. That'll really wake it up!:cornut:
Possibly do? We have more options. And I quote the Randman "speed costs money, how fast you wanna go!?!"
FatCat
2 stroke Addict!
Ottawa, IL
The odyssey world has the same problem. All the guys in the desert never see sleds. I should buy a trailer full and road trip. Save some room for the Ody and get a free riding trip for my trouble. Come spring time they're a dime a dozen around here. Nows the season I'm buying riding mowers. People look at you like your crazy when you go to buy a mower this time of year. Crazy like a fox! I'll at least triple my money come April. Then use these funds to buy $50-$100 sleds in need of repair for next winter. Seems so simple. Not sure why others aren't smart enough to figure it out. I'll turn a $50 bill into $250 any time you'll let me.
Amped
Funny you bring up ninja engines . I just found a ninja 600 the bike its off of was had frame damage or something . A friend of a friend has it . He got it to build a mini sand rail. never got to it . I'm gettig the engine , frame w/ controls , wiring harness, gauges , electronics, and A PRO SHOP BUILT MINI SAND RAIL FRAME. All for $200.00. The frame needs work. No A-arms or rear swing (I"ll put independent frt & back). Been out side too so it has some rust. Only seen it on phone pic. I can get for a while though. Money tied up elsewhere. But he said its mine " Get it tomorrow next year it will be there" his words. He doesn't need the money. He is a civilian contract jet engine mechanic for the airforce .Hope to get it really soon though. I'm about 5 hr from Green Cove Springs. About $200+ in gas in my ol ford f150.
fowler
Bullsbrook West Aus
i wouldnt really call it too much for a buggy
id say it would be too small for a sand rail
iv got a gsxr600 (140hp) in a 400kg buggy and thats consided small
most have hyabusas or zx14s
but with swing arm rear is a waste of time in a buggy
that is a wicked score
have u got any pics
u had better start a new thread for it though
