Needing help please!!
josh13
"i just got a go cart with a "quadzilla" engine on it ..... the only numbers i find on it are on the trans case and they are LH152QM1 1126553 any help on determining what this engine is so i can find some kind of manual for it...i need a wiring diagram"
HaM551
Perth, Western Australia
Is Lh152qm1 on the engine case ?
HaM551
If it is have a look at a thread I made might help decode it, I got Lh is the manufacturer, 1 cylinder, 52mm bore, forced air cooled, 250cc, and model version 1
However the M can represent for motorcycle use or 250cc, I am assuming its for 250cc, it should say somewhere on the engine ? Look for a 250cc or 250 cm3
Hope this helps, try searching Lh motorcycle manufacturers, this is for Chinese engines only btw
josh13
I'm pretty sure it's on the trams... Haven't had time to fully check out the motor yet. Just got it earlier today but I will check first thing in the morning
josh13
Well I've been looking at it pretty much all day... Not much luck on the wiring. Still no spark but I did find out that it has pretty much the exact engine as my moped which is Chinese so ill backtrack the wires on the moped and wire them the same... See what comes up... Still wondering about the. "Quadzilla" word though ??? Anyone know
josh13
someway somehow i finally got a spark... put some starting fluid in and fired up first try.... now if anyone knows where to get disk brake parts at i would greatly appreciate it. just needs to stop now
cumminsbayou4x4
fairhope alabama
Suzuki made the "quadzilla'' it was a 500cc 2 stroke water cooled with a 5 speed transmission it should have the word Suzuki on the side casing somewhere
cumminsbayou4x4
fairhope alabama
godzilla had NOTHING at all to do with the 4 wheeler it was nicknamed quadzilla because it was just the biggest fast 4 wheeler of its time it wouldn't matter if it was chinese or Japanese
Okay, okay- don't get your shorts twisted...
Anyway- please be aware that the engine in question is not at all related to the Suzuki Quadzilla. This is a chinese thing. I have heard of these, and they have absolutely nothing in common.
... And what if it was Korean? :roflol:
