Tecumseh 10hp engine?
peterbilt
Denver,Co.
Just wondering if this engine is any good? Looked on Google and found out that its a generator engine. Does that mean that it doesn't have the speed and power as say a 6.5 motor?, I have this engine on my cart and I can't seem to peel rubber or do rooster tails in the dirt. Guess what I'm saying is that is doesn't have punchy throttle response. Also I have a centrifugal clutch. Any help would be greatly appreciated.
fowler
Bullsbrook West Aus
a 10hp engine has more power than a 6.5 in all measureable ways
it may not be as quick on the gas for a wide range of reasons
timing to age to rotating mass
id say it is because the cart is set up for speed
what is your gear ratio
count the teeth on the drive and driven sprockets
A kart that can do rooster tails wont have as high top speed but would have more acceleration
also kart wieght and grip has alot to do with it
why can a 2lt hatchback do a burnout but a 6lt 4x4 cant
lastly what is the general condition of the engine and clutch
are they both properly serviced and working to the best of there ability
post pics of the kart we always like to see people show off what they have:D
That about covers it. The only thing not mentioned was torque converter: pricey but worth the money...
FYI: If your gearing is set up for speed (which is very likely) setting it up to "loosen the back wheels" will mean a lower top speed
carter
14/60 comes out to about a 4.2 ratio, unless you miscounted, you're gonna wanna change that gearing.
peterbilt
Denver,Co.
Why would I wanna change the gearing? It moves pretty quickly. Just no get up n go power. Also what's wrong with the crank?
carter
Higher gearing=more acceleration. I'm surprised you got it to work with a 4.2:1 ratio (did I put that backwards?), I would do a 6:1 if I were having acceleration problems in that state.
fowler
Bullsbrook West Aus
If u wanna spin the tyres then u must sacrifice top speed for more go
There's nothing wrong with the crank
In some cases a generator engine uses a tapered shaft and u can't fit a standard clutch
EDIT
Carter that's the other way round
A 4.2 : 1 is an ok ratio
A 6:1 is going to give u more top speed and less acceleration
It's the number of turns of the engine : number of turns by the axle
peterbilt
Denver,Co.
Don't really wanna spin the tires, just wanna have some get up & go. Little bit of whiplash feeling ya know..
EDIT
Fowler, you have got it wrong. Compared to a 4.2:1 ratio, a 6:1 ratio is going to give you more acceleration, but less speed.
Hige gear ratio = higher speed, poor acceleration
Low gear ratio = lower speed, better acceleration
A 4.2:1 ratio is going to fry a clutch much faster than a 6:1 ratio
carter
yea where was i going there :mad2:
thats what happens when u try to rush a relpy at work:roflol:
I was honestly confused for a second. Happens to the best of us though, no harm no foul.
Doesn't 4.2 seem a bit steep without a CVT though?
A lower gearing will give you more "get up and go" however with the spinning tires thing, thats also dependent upon grip, tire tread, the surface you're on, weight, and a couple other factors.
I would say it is still slightly steep. 5:1 would maybe be better, but people have used 4.2:1. I think that was the gear ratio that Toystory had on his kart before he sold the engine
Actually, I was at 4.8:1, and that was WITH a CVT... and it was still a bit steep. If I were to stay with that driveline, I would have geared down a bit more, maybe 5.4:1.
I'm running 4.5:1 on my Alley Kat, but it's a very small, light frame. I will gear it down some more, to avoid mangling the clutch- it is not a high-quality race clutch just a basic Hilliard or MaxTorque- I have forgotten which.
This is what comes from reading posts too quickly. I thought he said with a CVT. Thanks Toystory
Sorry, my fault :eek:
Yes, they can be awesome engines!
Most of the speed/race-parts made to fit the Tecumseh Star engines will interchange on yours.
You can research the Star model here at this link:--> http://www.google.com/search?source...z=1T4GZAZ_enUS369US369&q=Tecumseh+star+engine
I raced my Tecumseh Star at go kart racetracks against several guys with 6.5hp Honda/clone engines. Some of those guys had spent up to $1500 building their engines up. I only paid $300 for my used Star engine and consistently won my heat and main-event races!
I think the Flathead 10hp/HM100-series & Star models were the best engines Tecumseh ever manufactured.
It's mostly just their overhead valve engine-models you'll see guys complaining about on the net... :thumbsup:
carter
I'd have to agree with that, my hm100 on my kart does everything I ask of it and more, and it doesn't complain. Plus its generally a low maintenance engine.
