I don't know you, and don't know how much experience rebuilding engines you have, so please don't take offense...but I'm cringing at the idea of just hand-honing an automotive engine that you like because "the bores had a mirror finish", even at 180K miles. The 5.7 V8 is a really tough engine, unless they're abused and/or run with filthy oil they often have near-prefect bores at 150-ish miles.
I hope you measured the bores before/after, and aimed at the crosshatch angle that your piston or ring manufacturer calls for.
If not, if you want that engine to run well and last, you need to:
Mic the bores to check for perfect roundness at the top, middle, and bottom of each bore. If they're not round, take it to a good machine shop where (depending on how worn the bores are) they'll either machine-hone or bore-then-hone the cylinders. A good shop (here in the US) will use a Sunnen machine. After honing, you MUST have the proper cross-hatch marks on the cylinder walls for the piston rings to seat properly - something that's almost impossible to do by hand unless you've got a LOT of recent practice.
My strong recommendation is that you take it to a reputable machine shop and have them mic the bores, then have them do whatever boring/honing they recommend based on those measurements. It'll cost you some $, but in the long run you'll be much happier, imho.
My fear is that you've (a) removed too much material, and (b) ended up with a scratch pattern that's nowhere near what's needed.
Again, I'm not wanting to offend - I just want you to end up with an engine that'll run well for a long time.
