engine wont fit now
kbar
I have a predator 212cc motor i took it off the cart to take the governor out change springs and throttle cable, etc But now it wont fit back on the mount I didnt move the mount at all. Any ideas heres a pic of the cart
kbar
bout 40 before all the upgrades dont know how fast now. It doesn't fit the studs are off about 3/4 inch
Fallenleopard
N.S.W Australia
Is the mount bent at all? the mount may have warped some how. but that would only cause it to be slightly out.
are you putting the engine on the right way? :roflol:
only goes on one way:roflol:
...And you haven't found that way. :roflol:
This is whay I always advice new mechanics to take notes and pictures while disassembling something. He//, I still do it occasionally if I don't have a service manual, or haven't cracked into something strange before.
I really don't know what to tell you. You can see where the problem may lie, I cannot. Just keep rearranging things 'till it fits. I doubt very much that it grew while it was off the kart!
What's in the way of what?
exenos
Project Nut
Try putting one a bolt through one set of mounting holes (through engine and plate) then rotate around that till the other holes line up.
That is good advice.
There is no way that things have gotten warped or bent unless you were beating on something to get the engine out.
The engine came off there, so it should go back on the same way. Have a look at all the engine parts that you removed, and make sure that they were put back on the same way. Sometimes you don't tighten a bolt the whole way and recoil covers etc (or whatever you removed) may sit skew.
