Back Pressure
South Kart3377
Kart designer
Va
Back pressure/Static Pressure is NEVER EVER NEEDED OR WANTED ON 4 CYCLE/STROKE. Straight pipes and/or Large mufflers make your engine more efficient, Powerful and in most cases just plain cool. If anyone wants to add please do below.
Sorry about my rant.
Skart
jfxwave
Corpus Christi, Texas
This is a Quote - not mine
"Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
So how did this myth come to be?
I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s)."
Thanks, Jfxwave- that needed to be said. Seems like daily, that I have to keep explaining that back pressure (aka static pressure) is BAD by definition- Cylinder scavenging is a whole other animal, and probably 3/4 of the planet can't seem to grasp this. Let me draw it out this way for the folks that don't get it STILL-
Suppose the ideal pipe diameter for your particular engine turns out to be 1". Now- you have a 1" straight pipe of say 12" long. Now exchange that for some 1" pipe that is also 12" long, but has several sharp 90* bends. Both pipes are the same I.D. And length. The straight one will have a very low static pressure value, the one with all the bends will have a high value. Obviously, the pipe with the high SP value will create a large back pressure value. Cylinder scavenging (as well as exhaust velocity) will suffer.
So- which one do you suppose will allow the engine's greatest performance?
machinist@large
West Michigan, 49331
How do people like you do it? I DO things at work that look complex; but, if you really look at it, they're not that bad. Problem is, trying to write it up on my timesheet.:ack2:
You've just taken a concept that I've read up on, studied, and have come to know some of the basic's of, and put it in such a neat, easy to read (AND HOPEFULLY UNDERSTAND!!!!) format. How do You do this? Or, more importantly, what have I failed to learn along the way? For me to explain something like this, I'd need at least three times as many words, and no one would understand me!!!:angelsad2::confused:
jamyers
Buffalo Gap, TX
you can run a motor with out any exhaust but you mess up the valves
Couple of reasons why running an engine without exhaust can damage valves, none of which have to do with pressure.
Without something at the head (exhaust manifold or pipe), the exhaust valve is exposed to outside (MUCH cooler) air between exhaust events. Getting hit with alternating 1300F then 80F air isn't that good for them. Not to mention the potential for getting garbage into the valve area.
Main reason I've seen people lose valves with no exhaust is they don't re-tune the engine when they remove the exhaust. The freer-breathing engine then goes lean, exhaust temps go up, and they burn a valve.
