briggs 5hp fuel problems
beansdaddy78
JR. Member
Carbondale IL.
HTML:
I'm trying to start this flathead 5hp briggs, it does start with starting fluid then dies immediately. Cleaned the carb still nothing, im cleaning it again right now and gonna try new gas with spark plug.
Any suggestions?
beansdaddy78
JR. Member
Carbondale IL.
If the fuel tank is under the carb, you may need to replace the pump diaphram; very common problem on this type of system
Yes the tank.is under the carb, also I replaced the diaphragm and spring and washer thingy already, just tore it apart again and used compressed air and carbon cleaner again and still nothing. I set the needle acre at 1.25" , is that proper?
Ok then, what about the pickup in the tank; is it clean & clear with no leaks?
I heard from a mower mechanic that these engines don't like being started when the fuel level is below 3/4 of a tank; is you tank topped up?
beansdaddy78
JR. Member
Carbondale IL.
Dang nothing, only starts with carbon cleaner. This has the carbon with the choke that slides out of the end of the carb, how do I get that choke to stay out, everyone I pull the cord it slides back in before I can even see If it works? I'm gonna try to post a pic in a min. Here. In case your not familiar with the carb
beansdaddy78
JR. Member
Carbondale IL.
Here is the pic of tge carb with the slide out choke. Any ideas on how to get it to stay put?
qtband
St. Louis, MO
Beans, do what Fabroman says. Fill the tank all the way. If that pickup tube has a hairline crack in it, it won't suck fuel. If you fill it up and it still doesn't start, at least you eliminate that pickup tube as a problem.
beansdaddy78
JR. Member
Carbondale IL.
Ok I got it to fire without carb cleaner, it puts a few times then dies. I guess it is a fuel problem. So do ya think I should gets new pickup tube just to eliminate that question? Also is there supposed to be a bracket that keeps the tube tight? My other old Briggs has one, could that missing be a pro Ken?
qtband
St. Louis, MO
I don't know about the bracket.
The guy where I buy parts told me that you can take the plastic pickup tube off and put fuel hose around the brass pickup tube. You need to make sure the tube is a tight fit in the hose. Only problem is, most of the time you take off the plastic pickup tube, it's junk. I bought a new plastic tube and tried the hose trick and it worked fine. I then took the carb back off, sliced off the fuel hose and put a layer of solder all around the brass tube sealing it. That worked.
I have heard that the fuel lines from weedeaters work well for this
Beans, wasn't this discussed with another of your engines?
beansdaddy78
JR. Member
Carbondale IL.
i believe it was discussed on another engine. however the motor was different i believe, now im not sure which one your talking about, please let me know because it seems to be a problem and i dont wanna be any more trouble than i already am. i remember another briggs 5hp that i had some problems with , they did both have fuel system problems but they were not the same problems.
i found that this one had a stripped screw that was barely hanging on in the diaphram cover. i took the screws out and tried another set of screws from one of the 3hp briggs i got laying around and they happened to fit nice and snug and now the motor is super duper.
now im working on getting the bent up elbow type 4" long bentpipe/straight pipe, it looks like someone tack welded it in. so ill use my trusty dusty dremel and remove the tacks sometime tonight. :D also welded for the first time in at least 15 years today, made a couple straight pipes for some motors and now that im not nervous to do it the first time anymore im gonna be making as much stuff as i can.
I wasn't trying to say "you should check what we've already told you before asking again", I was merely wondering what you solution was when it came up. I don't recall seeing anything about that solution but, I'm glad you figured it out :thumbsup:
Hang on, I'm confused; are you saying you fixed this engine or the other one?
This is the same type of carb as my daughters kart so, I had the same problem. I ended up making a choke control but I have no pics of it :censored::mad2:
It took a bit but, I got pics :D
beansdaddy78
JR. Member
Carbondale IL.
sorry, i misunderstood then.
im gonna try to work out somehting like you did on that one. i have two of these running briggs flatheads and the carb seems to need constant tightening. do you ever have a problem with the bolts that hold the carb to the blocke working loose??? would you recommend some locktight? if so which color, blue?
Let me know if you need any help or details :thumbsup:
I have two of these running briggs flatheads and the carb seems to need constant tightening. do you ever have a problem with the bolts that hold the carb to the blocke working loose??? would you recommend some locktight? if so which color, blue?
Just the other week in fact. The biggest problem is getting anything in there to properly tighten the bolts. I ended up putting a drop of blue locktite on each bolt, so far it's holding...
