Clucth problem.
Stevenf
Florida
Can you look at the last set of pictures I posted and tell me if the setup is right? I see two bushings but the belt doesn't sit on them. I posted another set of pictures with the belt on.
Have a look at this link around halfway down the page. It will give you an exploded view of the driver, showing where the bronze bushing should be. It is a loose bushing that rides on the shaft in the driver. The belt sits on it.
http://www.gokartsupply.com/asymapp.htm
I have added a pic of yours showing where the bushing should be. You would have taken it off when dismanteling the driver
Stevenf
Florida
Thanks for the picture. There was nothing there when I took it apart. The belt was just resting on the metal.
Stevenf
Florida
I ordered the part yesterday. Hopefully it doesn't take too long to get here. I'll post the results when I install it.
Stevenf
Florida
I got the bushing in today and installed it. It seemed hopeful but it did not fix the problem. The tires still spin like crazy. could it be a carb problem? What should i look at next to remedy this?
Have you completely torn down, serviced, cleaned, lubed the CVT? Absolutely sure you've got the correct belt? Engine idle set to spec? That's really all there is to this.
Make sure that bushing is able to move freely on the hub.
Stevenf
Florida
So i was cleaning and servicing the cvt as suggested and i noticed the outter drum is almosted striped from the hub. please look at the pictures. The first pic shows where the hub should sit in the outter drum. The second shows how the outter drum moves when the hub is in it. Also there are gouges on the inside of the outter drum. Do all these things mean its time for new clutch? What could have caused these things to happen?
