2 stroke vs 4 stroke motorcycle engine ?
Kaptain Krunch
Pro Junk Collector
vermont
generally four stroke will have better bottom end, better on fuel, last longer.
Two stroke generally lighter, louder, and a lot more top end power for their size.
Four stroke better for off road, two stroke generally better on. But it also depends. 200cc 2 stroke bike motor vs 400cc industrial four stroke, obviously the bike motor will be much better.
gvfc2
wishing i was living
Tacoma,wa
Wouldnt the 2 stroke be better because you cut the gas with oil? The 2 stroke has adjustable power band using a tuned exhaust pipe. Wait for people more knowledgeable
fowler
Bullsbrook West Aus
For what u want
A small bike engine on a Kart 2 stroke is the way
Really all u want to do is go flat out, foot flat to
The floor full time
The two stroke is very simple and in the smaller form (250 down) they are more powerful than there 4 stroke counterparts
If u were doing a large buggy or making a utility vehical ( farm quad) then 4 would be the way
More useable power and more torque low down (as was mentioned above)
fourtogo
Yes i can see how well the 2Stroke works in rear facing camera . http://i3.ytimg.com/vi/zDDJXBZzYEg/default.jpg . Ebay bought CRF450 Honda . Used Ebay frame . Used brakes and spindles . Used 40mil axel New Ebay radiator new oil cooler kit $25 lot of used wheels . I did buy a new seat and steering wheel . The lime green kart is a V-Twin 4stroke on Alkie and the rest are 2strokes. If you are going to put some power on, make it enough to make your self happy.
Kaptain Krunch
Pro Junk Collector
vermont
Power band is just a term, it simply refers to the hp/torque curve. Yes you can "adjust it" with a different expansion chamber on most, but you can never make the low end torque with a two stroke that you can with a comparable four stroke. However, with most two stroke bike motors, if you begin to bog out you can pull in the clutch and pin it for a second, and let out the clutch and you will be spinning the tires till you let off so lack of low end really isnt much of an issue.
FatCat
2 stroke Addict!
Ottawa, IL
I'll add a little to this. That term power band is when a 2 stroke is running its most efficient.(and making the best power) 2 strokes are very inefficient engines until they are in the power band. That's why the ATV world is moving to 4 strokes. **** EPA. You are correct that a tuned pipe will effect where the powerband is. This is just 1 piece of that. There are lots of other things that also effect this. For the common guy looking to upgrade parts a tuned pipe will give you a lot of bang for your buck. The other factors should be left to your engine builder. You start messing with port timing and other stiff you can make a paper weight of your engine in short order. The only issue I see with using a modern 4 stroke bike engine is cost. Sure they make great power in a compact package but initial cost may be high. If that isn't wait until rebuild time!(I don't know about the CRF but the TRX service manual calls for top end inspection every something like 20hrs.) These engines are pushing they're limits. Any time your extracting every bit of power you can your reliability will suffer. That's the trade they make. The biggest reason these engines fail is from gross lack of maintenance. When people find how much it costs to open one up they push it off, push it off, then kaboom! Another machine parted out on eBay because they couldn't afford the $2000 overhaul. That's my biggest concern here. Lots of guys on here are working with tight budgets. If the bottom end let's go I'm afraid it will put them out of business. I can also see problems affording the rigorous maintenance as well.(this is probably why most don't do it). These also run plated cylinders so that adds more $$ and time if that gets damaged. I personally don't think this is a good 4 stroke engine choice for budget minded people. Now if you can afford the price of admission and maintenance I'd say go for it. They're impressive. Just have it in the back of your head that it is gonna break, and break big so plan$$$ accordingly. As for me. I have castor oil running through my veins. I'll be playing with 2 strokes until the day I die. Bbbbbrrraaaaaap!
Kaptain Krunch
Pro Junk Collector
vermont
Agreed, two strokes are the way to go, I'll never buy a four stroke bike unless i wanna ride it on the road. Reeds are a very good simple mod also, stiffer reeds for top end, softer for low end. Two stage if possible for the best of both worlds.
FatCat
2 stroke Addict!
Ottawa, IL
I run a cr250 reed cage with boyesson fiberglass 2 stage reeds in my Odyssey. They work great. I don't know if it's much power but it definitely feels different and runs more lean than it was with the stock cage and reeds. That's telling me more airs going through. A good tip for fun cart or dirtbike/ATV guys is to avoid carbon fiber reeds. They claim they make more power than fiberglass. They do. For about 45min on a dyno then that number fades to the same as fiberglass. If your racing I understand but for fun they just don't make sense. The cost about twice as much as fiberglass. They are also more brittle. If your engine eats a fiberglass reed it usually throws it out the exhaust with minimal damage. Carbon fiber on the other hand chews **** up real good on it's way through.:cheers2:
