Question about Engines.
TehChikenHater
Do all engines have cylinders? Because here in my part of the United States, you MUST have a drivers license, and a license for the engine to have an engine with a 50cc+ cylinder. Do any of you know if Briggs and Stratton engines contain these? I heard not all engine have cylinders, and use a different method.
souperman000
Westlake Village, CA
pretty much all gas engines you will encounter are piston driven; all piston driven engines have cylinders.
you may have heard of rotary engines, which don't neccessarily have a "cylinder"
the 50cc's you talk about is the displacement. The cc stands for cubic centimeters. 50cc engine displaces 50 cubic centimeters.
anyone care to expand on stuff I missed?
That's it in a nutshell, really. There are many types of engines that do not have cylinders, of which you are likely to encounter ZERO- unless you're in the habit of playing with jets, turbines, rockets, the aforementioned Wankel-type rotaries.... The internal combustion engines powering cars, trucks, lawnmowers, whatever (including diesels) have pistons in cylinders.
To clarify the displacement thing a wee bit: The engine's piston travels up and down in the cylinder. It is the volume of that cylinder (or the combined volume of multiple cylinders) that equate to the displacement. This is most commonly measured in cubic centimetres (cc's), or in the old Imperial way, CID (Cubic Inches Displacement). the 50cc's literally equates to the effective volume of the cylinder engine in such a size.
I want to know more about your local regulations. I have heard of such licensing regarding mopeds and scooters, but I have NEVER heard of these regulations pertaining to go karts. Where are you from, and can you point me to where you found these laws?
For further engine theory, you need to read up on four-cycle and two-cycle internal combustion engine theory- this is basic stuff and should be understood by anyone who so much as operates an engine.
EDIT- Please note that a Cubic Centimetre is exactly equal to a millilitre (ml). A 1-litre engine, for example also equals 1000cc or 1000ml. The effective cylinder volume literally would hold a litre of water...
TehChikenHater
I live in Northern Virginia, USA. Here there is a law that you must have a drivers license, and a license for the engine if it contains 50cc's of cylinders or more. Now, I can go ahead and build a go-kart that has less than 50cc (49ccs, ftw), and not get pulled over, but, if I speed, I can. I was told of this from my Dad, who built a Go-Kart in college for an Engineering project, they were testing it on the streets outside of the University, and they were pulled over, and ticketed for having a 50cc engine.
souperman000
Wow that is really strict, I thought you were asking about the 50cc's for a scooter. Around here, you don't need a special motorcycle license to drive bikes under 50, but for above 50cc, and increasing from there, you need a higher class motorcycle license relative to engine size.
This is more like what I am used to seeing.
Well, if you're planning on staying under 50cc, you've got a tight build ahead of you. Keep it as small and light as possible, and keep tire size minimal, too. Every ounce counts.
fowler
Bullsbrook West Aus
u really need t look into these laws deeper
i think u may have mis read them
that sounds like a typical motoorcylce and scootor law
aplying to road going vehicals
the law u have found states u can not own a lawn mower or chainsaw
that sounds a bit extreme
TehChikenHater
My dad just told me about the 49cc in more details. I can have an engine with over 49cc, but it cannot be driven on the ROAD, without a license.
Once again- that's off-road motorcycles and ATV's. May state and municipal laws prohibit go karts on the road regardless of engine.
Please pay close note to the following VIRGINIA law, as found here---> http://leg1.state.va.us/cgi-bin/legp504.exe?000+cod+46.2-100
"All-terrain vehicle" means a three-wheeled or four-wheeled motor vehicle powered by a gasoline or diesel engine and generally characterized by large, low-pressure tires, a seat designed to be straddled by the operator, and handlebars for steering that is intended for off-road use by an individual rider on various types of unpaved terrain. The term does not include four-wheeled vehicles, commonly known as "go-carts," that have low centers of gravity and are typically used in racing on relatively level surfaces, nor does the term include any "utility vehicle" as defined in this section or any "farm utility vehicle" as defined in this section.
So, once again- engine size does NOT matter.
