Working on my first Go Kart Build
nlmvp99
Greenup, IL
Purchased a used frame and most of the parts needed except for motor, clutch and chain. It needs some work, but that's what make it fun. Should be a fun toy for my kids once it is complete. I also purchased a 5.5HP motor off of a pressure washer to use for this project. I will have a blog page up soon documenting my build, but have not got it all setup yet.
I do need some advise on a few things from any experts out there. This kart came with a 72 tooth sprocket on the rear axle. I will be putting 13" tires on the back so I am trying to figure out how many teeth I need on the centrifugal clutch so it goes a decent speed and creeping along. I don't need anything fast enough for racing, just enough for the kids to mess around in the woods with. Any advise would be appreciated!
Thanks!
Welcome to the forum! How old are your kids? You are going to want a clutch with the fewest teeth possible. Even still, it may end up too fast for little ones. In that case, you'll have to consider using a jackshaft to further reduce the ratio.
Welcome to the forum. Start a build log in the projects section and throw up some pictures of what you have. I would suggest that you get a 10T sprocket. This will give you a ratio of 7.2:1, which should give you decent torque and still be fast enough for kids. You could always get a 12T sprocket at a later stage to give you a little more speed. You will sacrifice some torque though
nlmvp99
Greenup, IL
toystory_4wd: My kids that will get to ride it are 11 and 8. The youngest is just 4 so he will have to wait a couple years.
landuse: Got my "before" pictures taken over the weekend and plan on starting work on it tonight when I get home. I will post pictures later tonight and keep it updated on here as well as on my blog site.
So a 10 tooth will be enough to get this to move decent for the kids. Like I said, I don't want a racer, but I don't want it to creep either. Do you have a good way of estimating what speed this thing would go with that gear ration? also, it is a 2 seat kart if that makes a different at all on the gear ratio.
If you look at THIS calculator, you will see that with a 10T clutch, you will get 19MPH out of your kart. That is pretty fast for a kid. If you use a 12T, you will get 23MPH. I would rather have more torque (10T sprocket) IMO.
A 10T would be great for your kids with 13" wheels
nlmvp99
Greenup, IL
I found that calculator over the weekend and played around with all the different combinations. Thanks for the advise! I appreciate the help. I will have pictures posted later tonight.
Please correct me if I'm wrong but, the minimum number of teeth on a clutch depends on the chain pitch. I've searched everywhere for a 3/4", #35 pitch, 10t clutch but I simply can't find one. I think the reason is that 10 teeth won't reach around the shaft.
A #41 pitch, on the other hand, comes in a 10t because the teeth are bigger...
nlmvp99
Greenup, IL
I need to measure the pitch on my 72 tooth axle sprocket, but I am pretty sure it is #35. I am having problems finding a 10T clutch to use with it as well. Do I need to consider switching out my axle sprocket or just go with the 12T clutch?
Even with a 12t, you'll still have a 6:1 ratio, which is fine. I think the guys are just concerned about that much speed in the hands of young kids. If you can incorporate a jackshaft to take it to around 8:1 or 9:1, do so. That will bring the speed down & leave the possibility to change it later when they get used to it
nlmvp99
Greenup, IL
Can you point in the right direction of the jackshaft that I would need to purchase? I have read a lot about them, but I am completely new to all of this so don't want to buy the wrong thing if I decide to go this route.
denhammotors
Stuart, Florida
You can buy 11 tooth clutches for #35. They are probably about just as common as 12T ones. That will give you 21 MPH, but that still might be to fast.
nlmvp99
Greenup, IL
May switch my rear tire size to 11" diameter instead to avoid having to do the jackshaft. 11" rear tires with 12T clutch and 72T on the rear axle would put me at about the same MPH as the 13", 10T and 72T setup. Only reason I was going with 13" tires on the back was to give it a little more ground clearance. Do you guys think this will work fine?
Smaller rear tires are an effective way to reduce overall speed at a given ratio. That said, do be sure to doublecheck spprocket diameter before committing to anything. Sprocket diameter at a given tooth count will vary according to it's pitch- ie, a 72T #40 sprocket will be a fair bit larger than a 72T #35 sprocket.
nlmvp99
Greenup, IL
I will be working on it quite a bit tonight and I will double check that. I am pretty sure it is a 72T #35 though. When I bought it it had 10" tires on it, but my concern is that my kids will most likely be using this in the woods on trails that we have cleared. No climbing or anything like that, but definitely possible to run into something that might catch on the bottom.
Here is an example of a jackshaft kit. The only problem with this particular kit is the limited sprocket sizes.
It is rather easy to make a jackshaft; all you need is a keyed shaft, 2 pillow block bearings & 2 sprockets...
