I used to hate the pulsa-jet carbs, but I'm starting to like them because they'll take rough terrain better than most float-bowl carbs.
Yours is a 135212 like mine, what is the "Type Number"? Should be printed/stamped right after the 135212 Model #. Unfortunately, Briggs made bazillions of type numbers for each of their bazillion model numbers, and often the only difference is something stupid like a checkball...
The links that landuse posted are great info. From what I've gathered, the checkball is only to help keep fuel from back-draining while the engine is off, so that the carb has fuel for starting sooner. BUT: Keep in mind that if the tank is full, so will the "bowl", so the carb will have all the fuel it wants for starting (regardless of checkball) - which is why it's a good idea to top off the tank before cold-starting.
FWIW, I had mine apart yesterday, and it didn't have a checkball. Do you remember if there was fuel in that little bowl inside the tank when you removed the carb? These carbs use intake pressure pulses to pump fuel up the long carb tube, dump it into that little bowl where the carb picks it up from. 90% of the problem with them is the fuel pump, and replacing the diaphragm/flapper-valves often works wonders.
