How does Torque Converter attach to live axle
set2stun
Falling is just flying without ascension
Myrtle Beach, SC
This is a very newb question but i was wondering how a torque converter connects to a live axle. I understand that there are two pullies on the torque conveter itself but do you have purchase an additional clutch or something to attah to the srocket on the liv axle? Like i said i am a newb (and a girl) but very interested in putting a torque converter on the cart i just built.
MARGR4V3Z
MICHIGAN
You usually run a Jackshaft behind the engine. Connect your small sprocket and Driven to the jackshaft. I posted a picture of the setup!
Welcome to the forum set2stun
The TC is all the clutch that you need for your kart. Depending on what type you buy (I would recommend a 30 series Comet if you have the 212cc Predator), it will come with a backplate and jackshaft setup. You have the driver on the engine, the driven on the backplate, and a small sprocket that would go to the sprocket on your axle. You can see this in the pic above, except that there is no backplate on that one.
I have included some pics on the installation of the 30 series TC. I know they are a bit small, but it gives you an idea.
If you go for the 40 series comet, there is no backplate, and you then have to use a jackshaft setup. It will look like the pic that MARGR4V3Z posted
I hope this helps
set2stun
Myrtle Beach, SC
You guys are so awesome! Thank you so much and this answers my question. I have added another picture of my first attempt at a go kart. I think i'm gonna build another one with a torque converter.
r_chez_08
Should be in the shop...
Cornwall, UK
Not bad for a girl :roflol:
No seriously, nice one :thumbsup: I swear you are like the second gal who has ever posted on here ;)
You might want to put some padding, and some side supports on that seat though. Looks painful on the arse, and you could easily slide off.
Just one thing- Your steering will perform better with slight toe in, rather than the large toe out, like in the first pic.
I agree with r_chez on the padding and side supports. If you go round any corner, you are going to slip right off. Or install a bucket seat. That would work.
Did you use a bed frame as your base?
set2stun
Myrtle Beach, SC
Wow . . you guys are great! I actually welded the frame from scratch. I bought a seat for the cart this weekend and also put some rails on it. I don't have pictures of those yet but i have added some picture below of the progress. I am always up for some suggestions. You couldn't be more right about the toe in issue. The cart tens to slide when turning so i am going to have to rebuild the front-end. I also might change the gear ratio because it has a heck of a time starting in dirt. I am presently using a centrifugal clutch and a 60 tooth sprocket. I think i need less teeth. Let me know what you all think. Thanks again . . Christina
qtband
St. Louis, MO
I always wanted a son but I had 2 wonderful girls. Sure wish I would've taught them to weld! Your Dad must be proud. Nice kart!
Regarding the gearing issue, what tooth count do you have on your cent clutch? Assuming you have a count of 10, your ratio at the moment is 6:1, which is about the norm for a kart with wheels the size of yours. If you say that it is hard to get going in dirt, you might have a 12T clutch that will give you a ratio of 5:1. This ratio is higher than your 6:1 (the lower number means higher gearing). The higher your gearing, the faster your speed but the lower your torque. Torque is the push you back in your seat feeling when you hit the gas. When you gear too high though, you tend to burn up the clutch.
For you to gear lower and get more take-off power or torque, you are going to have to either decrease the clutch tooth count, or increase the axle sprocket tooth count. Sometimes getting a bigger axle sprocket is not practical, just because of the ground clearance that you might have. You don't want your sprocket dragging in the dirt. When this happens, and your cent clutch is the smallest tooth count you can get, then you have to start looking at a jackshaft to get compound gearing. You can then use several smaller sprockets to get a lower gear ratio.
So the higher the gear ratio (smaller number) - more speed less torque. You could also burn your clutch up. The lower the gear ratio (higher number), the more torque you have and lower your speed. There is always a trade-off between the two, and you have to get the ideal for your situation.
I hope this helps.
set2stun
Myrtle Beach, SC
Thanks guys . . I'm building this cart for myself. I'm single with no kids . . Just a tomboy at heart.
set2stun
Myrtle Beach, SC
Yeah i rode it but my steering is messed up. I worked on the front end today though. I am trying to do a toe in design.
Wow, thats also quite the welding setup, nothing cheap there. Ranger 10,000? That kohler 25hp V-twin sadly kinda dwarfs our measly 6.5hp we so commonly have around here. Looks brand new too.. Good stuff. How much u spend on that?
