Governor removal 5HP Briggs
a1parrothead
Hello all,
I just put a 5 HP Briggs on an old Dune Cycle, replacing the original. My question is, can I just remove the linkage rod from the throttle that connects to the governor arm to disable the governor? Or, do I have to open it up and remove the gear from inside?
If I just remove the linkage rod, do I need to rotate the governor arm one direction or the other? Meaning somehow all the way clockwise or counter-clockwise?
I am looking for the quickest way to disable the governor.
Thanks, Jeff
the general rule is when you remove the govener:
-remove every part of it, including internals.
-keep stock valve springs
-you shouldn't need upgraded internals if you follow the two things above
have a read ~ http://www.diygokarts.com/vb/showthread.php?t=16518
I agree. Just bypassing the governor can cause some serious internal damage if the parts left inside decide to come loose due to the extra load on the engine from higher RPM's
