r_chez_08
Should be in the shop...
OK interesting setup. You will probably struggle to find a new hub for that right hand wheel. Are there any makes or markings on the kart?
You know what would be awesome though?
The two engines, stock or mildly modified, connected by a jackshaft. Run a sprocket from engine to jackshaft, then have some form of clutch from jackshaft to rear axle.
Have the engines setup so that one is on power stroke whilst the other is on exhaust stroke. This way it would be similar to having one two cylinder 288cc engine. Awesome!
You would probably have just over 10HP, providing you don't modify. You could run either a heavy duty 3/4" clutch from jackshaft to axle, or go all out with a comet 30 or comet 40.
Would be sweet.
Jackshaft and sprockets and chain would be around £60. Cent clutch if you need a new one would be £40, and a torque converter would be £2-300.
BTW if you need anything machined (i.e. lathe and mill stuff) give us a shout! You are in the UK, right (IIRC?!?)
Would be sweet.
