stratguy44
Now that the weather has cooled down so my shop doesn't feel like an oven I can begin on a new kart build. Worked this past weekend on frame and front suspension. Here's what it looks like so far.
???make sure your upper and and lower a-arms are parallel with each other... everything needs to be equally parallel to each other, and pivot at the same angle. if one thing tilts at 10 degrees, then everything else has to tilt at 10 degrees too. look at it from the top, everything needs to be equally parallel too.
make sure your upper and and lower a-arms are parallel with each other. you can't have them be closer at the wheel end than they are at the frame end, or you'll run into some major issues. same for the tie rods. everything needs to be equally parallel to each other, and pivot at the same angle. if one thing tilts at 10 degrees, then everything else has to tilt at 10 degrees too. look at it from the top, everything needs to be equally parallel too.
If u think about it u do want the tyres to change camber as this means it will lean into the corners
